Boost setting
Old Apr 27, 2006 | 07:47 AM
Mark 3D's Avatar
Mark 3D
Moderator
Default Boost setting
I have been having major probs setting the boost correctly on my 3 door but eventually located the problems to the actuator being firstly a split diaphram and secondly the wrong PSI spring.
I have now replaced both of these and have now managed to get the boost right down (previously it was boosting at 22PSI)
ok so after adjusting the actuator the best i can do now seems to be 15-16PSI
Mine is running stage 1 for which i have been advised 14PSI my question is will i be ok running it at the current 15-16PSI as to be honest im fed up trying to adjust it anymore!!
Cheers,
Mark
Old Apr 27, 2006 | 09:51 AM
Mark 3D's Avatar
Mark 3D
Moderator
Anybody?
Old Apr 27, 2006 | 11:44 AM
Stu @ M Developments's Avatar
PassionFords Creator
16psi is normally fine. But only your tuner can answer whether or not YOURS is.
Old Apr 27, 2006 | 12:15 PM
Mark 3D's Avatar
Mark 3D
Moderator
Thanks again Stu!!
P.S I dont have "a tuner" lol you are all millions of miles away from me!!
Old Apr 27, 2006 | 12:23 PM
I think you car was running a superchips one Mark PM SCC to check boost recommendation.
Old Apr 27, 2006 | 12:30 PM
Mark 3D's Avatar
Mark 3D
Moderator
Cheers for the advice Phil.
JK12
33
Apr 26, 2021 12:09 PM
Marino
Sep 12, 2015 11:10 AM
markk
Sep 9, 2015 08:11 AM
Adam Graham
Sep 6, 2015 06:04 AM
turbowag
Sep 3, 2015 08:07 AM
