Pectal Loom help please!!
Old Apr 25, 2006 | 12:23 PM
lamb chops's Avatar
lamb chops
Default Pectal Loom help please!!
Just picked up my second-hand pectal loom from a friend for the cossy and am a bit unsure how to connect it to the existing loom?..
Does anyone know where this part goes to?
I haven’t taken my car apart yet but want to be informed as to what im going to find.. Is there a terminal block like this under the dash somewhere?
Any help would be appreciated
Old Apr 25, 2006 | 12:25 PM
SPADGE's Avatar
SPADGE
Your going to have to pin those wires out mate as those blocks arn't fitting into anything in your car! I'm guessing they were fixed to a purpose made track car car loom.
Old Apr 25, 2006 | 12:27 PM
DaveEscos's Avatar
DaveEscos
That white plug needs to be cut off and all wires conected to the battery. If i were you, id find the 'mate' of that plug, connect to some power cable and run to the battery.
you should also have a thin ign live feed to connect on the loom, and a rev counter wire
Old Apr 25, 2006 | 12:36 PM
lamb chops's Avatar
lamb chops
Wow thanks for the quick replies guys,
I don’t have any separate wires for the ign live and rev counter Dave but on the other side of the white block there is one small blue wire and two larger wires one with AC on it.. Dam can see this is going to be one of those jobs..
But I presume all of the red wires in that bunch all need to go to the battery, that’s a start at least..
Old Apr 25, 2006 | 12:38 PM
lamb chops's Avatar
lamb chops
Pulled back the sleeving and the other two wires are white if anyone knows where they go
Old Apr 25, 2006 | 12:47 PM
DaveEscos's Avatar
DaveEscos
they are prob your looms ign feeds
the loom needs the perms as per the white block you have
and an ign trigger
Old Apr 25, 2006 | 12:49 PM
SPADGE's Avatar
SPADGE
I had the same type loom and problem a couple of years back and got all the info off Harvey. Might have it written down somewhere and will let you know if i find it
Old Apr 25, 2006 | 12:53 PM
lamb chops's Avatar
lamb chops
Thanks guys!! You would be a star if you have it somewhere Spadge Well a bigger star
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Oct 24, 2015 11:11 AM
muz
Sep 30, 2015 08:29 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
