serious over fueling, ( 18 mile to a tenner )
Need a bit of info troops, my stg3 saff was never excellent on fuel but recently its got right bad, going about town not to hard, just a couple of bursts here and there i got 18 mile to a tenner. Now its not long been set up ( five weeks or so ) but ive recently changed my turbo, and put a new actuator on with an increase in boost of about 5 or 6 psi, the car runs great but my fuel consumpsion is terrible, i just started it the other day letting it tic over, then gave it a few revs and the kerb at my exhaust was covered in black soot, im gony get it set up again, but just wondering if its gony need any new parts or just tweeked a bit, any help or info apreciated
Originally Posted by ronf42
is it a moonstone saff with black wheels per chance , if so nice car, seen it about a couple of times.
No mate that was ma muckers ( rabmc ) from on here, its mercury grey with 17" rondells
Originally Posted by cossiegreg1
sounds like the water temp sensor is fooked.ggr has got them on sale for a tenner,
In what way does this affect your fuel consumption mate?
I`ve now changed my temp switch and my cars still the same, i havent drove alot of miles as i`ve been doing alot of other things to it, is there anything else off the top of anyones head that it can be
I no i need to see a tuner or rolling road but its to try and save my self from doing that till i reall need to
cheers
cheers
you changed turbo? to a bigger one???
and increased boost
after you had it setup????
if so, i'm sorry but thats asking for a DEAD engine
you u wasted your money getting setup
and increased boost
Explain why i wasted my money getting it set up it needed it so i got it, i was then told ( by the tuner) i would benifit from a larger turbo, so i got one, my car ran fine for at least a few hundred miles then started over fueling, and also explain why thats SO bad its asking for a dead engine, i have stopped using it so its not as if it will get bore wash or that. Im just trying to find out if i can sort it my self before taking it to the tuner again instead of ( as you put it ) wasting my money
and yes having a car setup for a certain turbo then changing it, WILL cause the car to run LEAN (dead engine) so yes it would have been better to get it setup with new turbo
or, done as you did and get it setup, then fit new turbo, then get the correct chip for the new setup and get it setup again.
any how why do i care, it's n iot my engine your gonna be damaging everytime the engine runs, and ask any GOOD tuner, if running a engine with the wrong chip will cause any perminant damage
happy motoring
NUTTIN RILLA
Howdy mate, same probs on my S1 buddy. Had it at AVA last month and its going back next month once i remember to book it in
My metering head and fuelling gear is coming out and getting some mods done to combat this prob mate, their your best bet
happy motoring
Cheers kev, i had that thought mate but im just looking for opinions just incase there was a more obvious thing
how`s your car anyway?
have you had your cO checked and adjusted? mine was doin about 30mile to Ł10 and cO was through the roof, had it adjusted and it was a lot better, is your mixture screw in your ecu ok? cos itl keep going back up if its fooked, i learnt this from mine also lol
Good stuff mate, i just changed the whole back end of my car, beam, arms, anti roll bar all with brand new polly bushes on everything, bit of pain but its done now, havent had the chance to reep the rewards tho still i shall get the fueling sorted out and then find out
Thanks alot mate, im just gony get it to the rollers and see if they can find it, hopefully it will be something like that
Originally Posted by Ian M
air charge sensor could have gone open circuit that would make it fuel max all the time.
cheers
its the brown sensor on the side of the plenum you can check it with a multimeter.
Thanks ian i shall check that tommorow mate
JK12
33
26-04-2021 12:09 PM
