Biggest brake discs you can get with standard 4x4 calipers?
What are the biggest brake discs you can use with 4x4 Cosworth Calipers and any links as to where i can get these discs?
Cheers in advance.
Cheers in advance.
Do you provide these kits Mike? How much of the caliper needs to be trimmed? Is there a 300mm disc available?
Resident Wrestling Legend
if you want a solid disc then you are better off looking at rear discs
i was thinking more along the lines of getting big discs from another vehicle that would be moddable to fit the ford range, the possibilities oculd be endless or even a set of RS focus discs bolted to the front would be fine if they were able to fit, anyoe tried this yet?
Caraholic
The front kit for a 4x4 Cosworth is £487.63 inc delivery and includes, 310mm discs (grooved), bells (annodised colour of your choice) and brackets. The calliper only needs a few mm ground off the inside at each end.
I wouldn't recommend one piece discs bigger than 300mm, purely because of the inherent warping problems all these type have (ask any Focus RS / Evo owner.... ).
jason_nike
18-08-2019 10:53 AM
FlashRS
13
31-08-2015 06:02 PM
track.focus'd
12-08-2015 05:53 PM
