CVH Sumps...................????
Do they just unbolt and come off or are there loads of other bits i have to unbolt first?
its coming off tonite, I am fuckin sick of that garage, they have "Took the rocker cover off"
THATS NOT WHERE THE FUCKIN PUMP IS THO IS IT
PMSL yes mate they litterally just unbolt.. 10 mm ratchet is all you need.. (although you 'may' have to take the starter motor off to get to a coupple of the bolts, oh and the gearbox shit shield thing too)
Dont go for the 3 peice gaskets when reffiting
Lower exhaust
Remove starter.
remove gearbox flywheel cover.
10mm sockets and long extension for sump studs.
When refitting tighten in a diagonally spaced out sequence and dont overtighten!
Lower exhaust
Remove starter.
Ah well, sump came off last night. Yes, the new owner did keep this car clean.................... shame the cunt didnt know what an oil change was
Fuckin sump was full of shite so everytime i booted it, all the crap went into the little gauze filter on the pick up and blocked it, hence no oil at top end but then starting fine the next day.
Wankers
So, new oil pump and a full flush being done today and will be out on the road ready for a thrashing tonight
Wankers
glad it aint fucked anything! how do the shells look while your there! for the sake of it, it may be worth changin the big ends at least. they are £25 from a motor factors!
Everything else looked fine Phil (well, looked fine)
Im not changin the shells yet, if they go, they go. I have had the thing a week and not driven it properly yet. The missus is sick mate, as much as I am. She aint even seen it in the flesh yet, lol
Don't refit it with gasket jizz if you can help it....if you use a rubber gasket, make sure the surfaces are TOTALLY clean from oil and it will seal...
People lace the gaskets with jizz and it squeezes out into the sump and the pump sucks it up.....it's alright in moderation but caking it on will only casue problems...
Already got me a nice rubber number Daz. I knew it would be that sealant shite, you could see it on the inside of the old gasket. Fucking cowboy bastards
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
