urgent info required regarding oil feed pipes on a series 2
Chasing Radders
got a m8 needs someparts to finish a turbo conversion but is not 100% sure what the parts are and where he can get them from
first off where top oil feed goes to turbo at the other end where it connects to the back of block next to the oil filter housing what is the bit that the pipe connects on too and where can he get one?
and secondly bottom oil pipe from turbo that goes to block he needs the bit that pushes into the block and the oil feed pipe itself?
and where can he get these parts from
the fuel pump brackets that attach the pump to the car
and the throttle cable bracket thats bolts on to the throttle body
help would be really apreciated as car being finished wednesday and these parts are all thjat is required to get it on the road
i got my oil feed pipe of ebay but you can get from burtons.got my return pipe from ford was about £37 for the rubber bit but im sure you can get rouse hoses that do the same job for half the price not sure you can still get the metal bit or not but im sure someone on here has one from an old block.
not sure if you can still get fuel pump brackets or not new for some reason i think you cant thats why some are cable tied up
and the throttle cable thing im sure you can gt bufty chrome ones of ebay for much cheapness
Originally Posted by Eagle
get some braided hose for the oil return .. easy to fit and forget that way
the t piece for the oil pipe would have to be 2nd hand im sure someone has one i did bt chucked it last month with my old block
oil return pipe i got one from roose motorsport and its doing its job plus nxt day delievery on that
throttle cable bracket again 2nd hand or ebay
fuel pump cradle, you can buy the main base from ford but thats it i got this and then i got the rst of the bits from as autospecialist in stainless steel, got some new rubbers and bolts from ford to complete the cradle
Ford Focus RS Parts for Sale.
02-06-2016 06:46 PM
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
JoeyBoyden
18-08-2015 10:52 PM
