urgent help pls guys!!!
guys im stuck, just changed my upper grille on my 04 plate focus for new one, put all screws back where i found them pushed the bonnet down to lock and click! it locks it just dont unlock anymore!!!!! then i found a little screw, now i remember that i think this one came from the top of the bonnet lock. now im confused on how ford wiould have a little screw working the lock!!!!!
i have a foci that i can open the bonnet. the lock is not moving!!!
any ideas!!!
any ideas!!!
You sure you havn't trapped a tool or something on the slam panel thus putting pressure on the bonnet forcing it against the lock? Try pushing down slightly around the lock area on the bonnet and try the lock at the same time.
Don't know then mate
Can your remove the grill with the bonnet shut to access the lock?
good news!!!!! me dad fixed it!!!! simple when i thought about. ..
the thickness of the powder coated steel didnt let the key go fully into the lock...
method - lean on grille
result key went in far enough and hey presto lock unlocked!!!!
dange
Ford Mondeo Including ST
23-09-2015 12:11 PM
