yet more SPA probs
yet more SPA probs
Fooking hate these gauges
after messing around with the wiring to the oil pressure gauge it now reads alot lower than it used to.
got me really paranoid even tho the prob started right after i re-did the wiring.
problem is, the pressure is spot on at idle but never really rises as it should.
for example it used to be 79 psi at cold start idle now only 65 then at hot idle would be about 28-30 which it still is.
As you drove the car and the revs incresed it rose up to 50-60 psi under normal driving.
Now it wont rise over 40 psi no matter how high the revs are??
if by some weird coincedence its not the gauge whats the worst im looking at?
pressure relief valve in the pump jammed or something?
Originally Posted by Andy_R
I still think its a Euan problem relating to you messing with the wires
Seems to much of a coincidence that this happened after you did what you did.
I think your panicking over nothing mate! Chill
have bought a high tec TIM oil press gauge so will get that hooked up to confirm and get the SPA sent back yet again...
think its narrowed down to the sensor for oil press as i have hooked the plug for oil press onto the boost sensor at it reads fine.
another new sensor needed i think
CabrioTurbo
01-08-2015 11:04 AM
