Smoke from under turbo on RST, what would cause this?
just been out in the garage trying to sort the RS, after a day of fiddling it started, but smokes a tad from under the turbo, dont have time to get underr itbut curious as to what the smoke could be, i was thinking it was maybe old oil in turbo as it has been started in so long or maybe starter motor
only on tickover as i havnt driven it yet, as its been standing for soooo long i need to check the brakes etc, The oil return could be possible as i had great trouble finding an oil return pipe to fit as its a cossie T3 and the oil return woulndn't fit, so have bodged an oil return, so will make sure thats the first thing i check
Originally Posted by xr4x4rs
well ive just fitted a cosy t3 to my cabs but put it inside ethe erst exhaust housing
i just used the standard rst t3 metal pipe and rubber hose no probs
well alss i used was the compressor hosuing and the middle section where the water pipes and oil feed go on
as its a t3 the cosy turbo fits into the rst ex housing so i didnt need to modify my exhaust as alls i could get hold of at the time was a cosy one and i knew i could fit it
everything from the escort turbo bolted straight on
just had to move the comp housing round a bit
Matt Baxter
16-09-2015 09:30 PM
