So who has what to do for the Ring???
I've got mine up and running in the last 3 weeks, clocked up 1500 miles, had it mapped ( only 35psi tho' ), and broke a load more stuff on it. So i gotta;
1, fit my Bernie box
2, fit my diff
3, fit my new rad
4, fit my new oil cooler
5, fit my new driveshaft
6, fit a new petrol tank
7, find the wheel wobble/knock problem on the front
8, replace rear brake pads
9, oil and filter change
10, fit new clutch cable
Should keep me busy for a couple of nights
And my passenger thinks he's got a load to do!!!!!!!!!!!!!
2, fit my diff
3, fit my new rad
Originally Posted by nightdavva
Fit new big wing sump & gasket
Oil & Filter Change
Re fit the alloy Rad
Get some road legal slicks or new tyres
General spanner check.
Await for Mike R's only reply of.......Brim the tank
Oil & Filter Change
WHO`S gonna be busy....
You!!!!
Team HOTHOT!
Originally Posted by Stu @ M Developments
Originally Posted by Graceland
Brim the tank and while driving there, bed in the brakes
job done
job done
Mine was to fit a a new lower column (knuckle has suddenly got play in it) and set up the geometry. Also not sure how much brake pad material is left.
Oil change.
Modify down pipe
Turn boost up from 26 to 32 held.
Check all suspension nuts and bolts.....
Oh and hammer the hell out of it.....LOL.....
Roll on that thursday morning 3.00am start
Modify down pipe
Testing the future
as of today, i have to fit:
starter motor
alternator
PAS pump
cylinder head
rad
intercooler
all pipes / hoses
engine loom
propshaft
convert scorpio diff and fit
exhaust
oil up gearbox and diff
run in engine and do an oil and filter change
plenty more. all good fun isn't it?
starter motor
alternator
PAS pump
cylinder head
rad
intercooler
all pipes / hoses
engine loom
propshaft
exhaust
Caraholic
Paul,
Actually, I have to take the car cover off first . It's all cleaned and prepped already .
Just make sure sure the exhaust studs are tight this year
Testing the future
starter motor - fitted
alternator - fitted
PAS pump - fitted
cylinder head - fitted
rad
intercooler
all pipes / hoses
engine loom
propshaft
exhaust
alternator - fitted
PAS pump - fitted
rad
intercooler
all pipes / hoses
engine loom
propshaft
exhaust
scorpio diff doesn't need converting. i removed one of the output flanges, but couldn't replace it with one from the cossie diff, as they were different lengths. everything was more centred in the scorpio diff, so the short shaft was longer than the cossie one, but the long shaft was shorter
anyway, apart from the rim around the outside where the driveshaft bolt ups, the bolt pattern is the same so it should just bolt in. had to change the rear housing cover though of course, as it mounts to the beam and floor differently in a scorpio
Testing the future
no alex. taking the 'ring taxi back to the fatherland after an engine, gearbox and brake rebuild to leave it there as the other 2 co-owners live there.
will be my holiday car whenever i go there, or if i fancy a drive down to the alps
deathrider666
28-09-2015 06:12 PM
SMILER258
28-09-2015 09:04 AM
