cosworth plenum spacers any gains on using one
the plenum spacers that gets put on cossy are they worth it do you gain any thing or is it for show any one put it under any test for results
2Evos & 1 Escort Van :-)
A good alternative IMHO is the Zoo / A1 Rally Sport/ Mike Rainbird Swedish style plenums - that get rid of the restrictive inlet elbow of the standard plenums.
I sold one on ebay the other day and have another to go up soon.
Doug Stirling's car runs 564 bhp using the Stainless one my friend made, so seem to work okay.
Although saying that AFAIK Rod's car doesn't use a Swedish plenum, and that also runs / ran ok!
Simon
Simon
Originally Posted by abdr500
what about if your not running 600 bhp would ther be any gain
CUNT!
Location: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
...its the distance between trumpet and cover
Thats right - the inlet trumpets are ridiculously close to the cover! Considering the cost of 10mm spacers I don't think you can go far wrong with them.
As mentioned the Swedish style plenums are a good alternative but don't really see the point unless you're going for big(ish) HP when you compare the two options pound for pound.
think thomas have done some testing on the manifolds.think he said it was 4-6% difference between the worst and best cylinder.
it was about the same as a MIS inlet iirc
Caraholic
We have flow tested the Swedish items . : http://www.randbmotorsport.co.uk/sho...sp?ProductID=5
These particular ones have been subjected to extensive engine dyno research. Obviously I cannot vouch for any other items .
Caraholic
Originally Posted by bud-weis
the swedish ones are a bit overkill though aren't they?? (for 90% of cossies)
and from what i've seen throttle response is shite on them
I can't understand people's obsession with buying things they DON'T need .
Norris Motorsport
Gareth, throttle response is not the same as TFC mapping.
Throttle respsonse refers to the time from throttle opening to engine response, and allthough correct TFC mapping is vital for smooth operation, it cannot change the laws of physics. (i.e. huge plenum volumes)
Norris Motorsport
Hi Gareth,
Indeed I agree, fitting a larger plenum without remapping the TFC is a recipe for flat spots and hesitation!!
However even when mapped correctly there is a noticeable suggish response in the engine when fitted with large volume plenums, especially when pressing the throttle from idle conditions when the engine VE is at its lowest and the plenum volume at its relative largest compared to engine air consumption.
ahh thanks karl
would you class a swedish style plenum large in volume? i havent measured one, but they dont look like they have a massive volume
Caraholic
Its kinda a T4 but not like that on yours LOL - its much better
Yeah as noble's stated i have 9bhp more than the saff at the wheels and going on RW's rst and nobles RR i reckon ure well down the line - 420ATW i reckon on AVA's
Mike have you connected up the water supply on your front brakes yet
JK12
33
26-04-2021 12:09 PM
