ecu pins
pin 1 earth
pin 19 earth
pin 2 lambda sensor
pin 20 positive power feed
pin 3 crank pos sensor
pin 21 not used
pin 4 crank position sensor
pin 22 knock sensor
pin 5 distributor connection
pin 23 distributor connection
pin 6 knock sensor with earth bonding sheild
pin 24 ignition module pin 3
pin 7 canister purge valve
pin 25 ign module pin 6
pin 8 electronic control loom
pin 26 not used
pin 9 linked to pin 30 (MAP and throttle pos)
pin 27 electronic control loom
pin 10 EFI power delay relay in fuse box
pin 28 fuel pump relay
pin 11 map sensor
pin 29 coolant temp sensor
pin 12 not used
pin 30 map sensor and throttle pos sensor
pin 13 octane adjust
pin 31 air charge temp
pin 14 octane adjust
pin 32 injector 2
pin 15 map sensor
pin 33 injector 3
pin 16 boost control valve
pin 34 idle speed control valve
pin 17 throttle pos sensor
pin 35 injector 1
pin 18 injector 4
pin 19 earth
pin 2 lambda sensor
pin 21 not used
pin 22 knock sensor
pin 26 not used
pin 11 map sensor
pin 12 not used
pin 32 injector 2
pin 15 map sensor
pin 33 injector 3
pin 35 injector 1
pin 18 injector 4
This is correct as per Ford wiring diagram for the Escort Cossie large turbo....
Pin 1 - Earth (brown)
Pin 19 - Earth (brown)
Pin 2 - Lambda sensor (brown/white)
Pin 20 - Power (red)
Pin 3 - Crank position sensor (brown/yellow)
Pin 21 - Not used
Pin 4 - Crank position sensor (green/red)
Pin 22 - Knock sensor (blue/yellow in shielded cable)
Pin 5 - Distributor phase sensor (green/yellow)
Pin 23 - Distributor phase sensor (black/red)
Pin 6 - Knock sensor (black/yellow with brown earth from shield)
Pin 24 - Pin 3 Ignition module (Black)
Pin 7 - Canister purge valve (brown/white)
Pin 25 - Pin 6 Ignition module (black)
Pin 8 - Electronic control loom (blue/white)
Pin 26 - Not used
Pin 9 - Connected throttle pot wire (Pin 30 red) (white)
Pin 27 - Electronic control loom (blue/yellow)
Pin 10 - EFI power relay pin 85 (relay 8) in fuse box (plug M3BB at fuse box) (blue/yellow)
Pin 28 - Fuel pump relay pin 85 (relay 9) in fuse box (plug M5B at fuse box) (blue/gree)
Pin 11 - Map sensor (shielded) and link to common connection* (brown/green)
Pin 29 - Coolant temp sensor (black/green)
Pin 12 - Not used
Pin 30 - MAP sensor and throttle pot sensor (red)
Pin 13 - Octane adjust (black)
Pin 31 - Air charge temp sensor (red/green)
Pin 14 - Octane adjust (black)
Pin 32 - Injector 2 (brown/black)
Pin 15 - MAP sensor (black/red)
Pin 33 - Injector 3 (brown/black)
Pin 16 - Boost valve (brown/yellow)
Pin 34 - Idle speed control valve (brown/yellow)
Pin 17 - Throttle pot sensor (black/red)
Pin 35 - Injector 1 (brown/black)
Pin 18 -Injector 4 (brown/black)
*Pin 11 (brown/green) connects to the following....
Coolant temp sensor
Throttle pot sensor
Aircharge temp sensor
Pin 21 - Not used
Pin 26 - Not used
Pin 12 - Not used
Coolant temp sensor
Throttle pot sensor
Pin 21 - Not used
Pin 26 - Not used
Pin 12 - Not used
Coolant temp sensor
Throttle pot sensor
Pin 21 - Not used
Pin 26 - Not used
Pin 12 - Not used
Coolant temp sensor
Throttle pot sensor
very helpful so far pins 12 and 21 are used for aircon,that only leaves pin 26,what is this for? its connected to the ecu inside but ive looked at the ecu connector and there isnt a pin in the mutiplug for this one at all,im wondering if this is the earth i need to run the aircon?
muz
30-09-2015 09:29 AM
DixieTheKid
14-09-2015 10:04 PM
