where to place EGT and LAMBDA sensor????
on a cossie yb.
where should i put the EGT sensor and LAMBDA sensor??
have bought this
and this
and wonder where is the best placement for the sensors
have bought this
and this
Testing the future
in the top of the downpipe, just after the turbo for the lambda.
for the egt, you have a choice of pre or post turbo. i have one in each port of my exhaust manifold
Nick,
Which thermocouples did you use and where from. I am about to istall a set up like you have but haven't looked at where to get the thermocouples from yet.
Thanks,
Doug.
Thanks,
Doug.
Testing the future
i got them from the german equivalent of maplin, www.conrad.de. i got inconel ones capable of withstanding 1200 deg. C, and then stainless steel compression fittings from RS Components.
i also got a 4 channel electonic handheld TC reader with rs232 output for datalogging from Conrad. but this one http://www.mglavionics.co.za/singles.html#TC-1 is very good for a permanent install.
https://passionford.com/forum/viewto...63279&start=80
i would mount the lambda down the bottom of the downpipe,,, here it will not get too hot and responce time will be next to zero
before anyone says,, i know i need new manifold studs/nuts
i turned up a boss wich screwed into the standard lambda hole, then a 3mm thermocouple gland could screw into my boss
rsguy
44
29-09-2015 03:29 PM
wheelwizardrefurbs
22-09-2015 05:45 PM
mike elsome
14-09-2015 04:08 PM
Si B
12-09-2015 06:49 AM
