General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
what about the power figure, would you say it is realistic?
Engine: Audi A3 20V Turbo engine code AGU, Jabbasport ceramic coated inlet manifold with green injectors, IHI rollerbearing turbo (VF24 Imprezza), Jabbasport down pipe and flexi, Mercedes Sprinter front mounted intercooler with custom made stainless steel boost pipes, Forge Motorsport dump valve, green cotton cone filter, Jabbasport chip and live map with later ECU, 18T 5-speed gearbox, uprated clutch, Passat TDI drive shafts and cv joints, Corrado 2.9 sub frame, upgraded engine mounts. I Have used all of the Audi A3 wiring harness and still retains the original transponder key. Most importantly this car still has its OBD diagnostic port for accessing the ECU for all fault codes and live testing of this car.
