MSD top work!
Old Mar 14, 2006 | 04:08 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
Default MSD top work!
Just got my stage 3 closed loop set for my saff, What a difference! drives soooooo smooth, and great power.
Cant recomend it enough, absolutly spot on
Arrived in the post at 9.00 am!!
My gearbox isnt quite so impressed , 5 miles and lost 4th gear....... i knew it needed changing but thought i would a while out of it, collecting another on saturday.
THANKS GUYS!
Old Mar 14, 2006 | 04:36 PM
D19 STE's Avatar
D19 STE
As also said here https://passionford.com/forum/viewtopic.php?t=183082
Sorry to hear about your gearbox
Old Mar 14, 2006 | 05:04 PM
Stu.H's Avatar
Stu.H
always heard good things about MSD.
Old Mar 14, 2006 | 05:13 PM
JTECH James
Passion for Fords!
i tried to explain that to my gearbox but its not having it.
Old Mar 15, 2006 | 10:07 AM
JTECH James
Passion for Fords!
the only thing i could do with finding out is when setting the boost, the instructions say for a t34. 63 25 peak, and hold 22 psi.......... i have a t 34. 48, so is it the same boost level????
Old Mar 15, 2006 | 10:40 AM
Sticky.'s Avatar
Sticky.
Seems to be MSD's week
Old Mar 15, 2006 | 11:03 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Phone and ask
Steve.
Old Mar 15, 2006 | 11:15 AM
Stu @ M Developments's Avatar
PassionFords Creator
Thanks for the kind words, sorry about the box, lol
Instructions:
Sorry pal, same boost level for both turbos, the 2 different maps just have different fuel levels in them.
Old Mar 15, 2006 | 11:18 AM
JTECH James
Passion for Fords!
Thanks stu.......
Old Mar 15, 2006 | 12:16 PM
gingeRS's Avatar
gingeRS
Default Re: MSD top work!
THANKS GUYS!
was the car already stage 3?
i'm thinking about getting this to improve my fuel economy as in london you spend alot of time in traffic and crusing at low revs
how much effort to fit?
Old Mar 15, 2006 | 12:24 PM
JTECH James
Passion for Fords!
i was running my new engine in on a stage 1 chip, so i changed over to stage 3, 7.2:1 gas flowed head etc.......... my car is a k plate saffy, so it was already wired with a lambda etc, so just mod the board a bit so the taller chip fits inside the ecu cover....... but reading the instructions its not hard to convert a non lambda car, just need to weld a boss into the exhaust and wire it in to the ecu,
So far its much better on fuel than the stage 1 at 9 psi !!!! for running in purposes. i do alot of traffic in exeter and this is deffo the way to go.
If you crive within the paramiters of the closed loop,as the instructions tell you it is great on fuel.
Let me know if you want more info mate.
Old Mar 15, 2006 | 12:46 PM
gingeRS's Avatar
gingeRS
well mines currently stage 3, just though this may improve fuel economy, have only had the car for a month now, so havent even used a tank as its a weekend car. will use a few tanks and get an idea for the economy, then possibly covert over to closed loop and see the difference.
mines a 1992 with lambda etc already installed.
Old Mar 15, 2006 | 12:52 PM
JTECH James
Passion for Fords!
dont wait then just do it, chip change all done! you would need to remove the pectel board, and put the original back in though, as the closed loop chip doesnt use it.
on a run they can 38+ mpg
Old Mar 15, 2006 | 01:24 PM
gingeRS's Avatar
gingeRS
i think it still uses the original board
satying that i dont know what a 'pectel board' is
it has a power engineering stage 3 chip in it
if i need the original board and i dont have it i am a bit stuffed really.
Old Mar 15, 2006 | 01:37 PM
JTECH James
Passion for Fords!
i think most stage 3 conversions you change the small board the chip sits into aswell..... just give stu a call, he will know for sure.
Old Mar 15, 2006 | 01:47 PM
cosworth87's Avatar
cosworth87
Sorry for being stupid. but what is 38mpg in km/liter?
Old Mar 15, 2006 | 01:49 PM
JTECH James
Passion for Fords!
lots
Old Mar 15, 2006 | 02:04 PM
cosworth87's Avatar
cosworth87
My sierra DOHC estate goes around 14 km on a liter. or uses. 0.7 liters on 10km. if thats helps.
Old Mar 15, 2006 | 02:08 PM
JTECH James
Passion for Fords!
yep, its deffo lots.
Old Mar 15, 2006 | 02:20 PM
gingeRS's Avatar
gingeRS
38mpg
is 8.26 miles per litre
which is 13.21 km/litre
assuming (1 gallon = 4.6 litres)
Old Mar 15, 2006 | 02:22 PM
JTECH James
Passion for Fords!
smart ass
Old Mar 15, 2006 | 02:24 PM
JTECH James
Passion for Fords!
so its vewry similar fuel consumption........... but me cossie is nearly 350bhp
Old Mar 15, 2006 | 02:44 PM
gingeRS's Avatar
gingeRS
can you do me a favour, next time you fill up, reset the trip counter, and run it down, then pm me with how many miles you got from the full tank
would make for an interesting comparison
out of interest, how big is the tank on the saff, mine was low the other day so i filled it to the brim and got 46 quids worth in, can i assume its a 50 litre tank?
Old Mar 15, 2006 | 02:47 PM
JTECH James
Passion for Fords!
yep, im on about 46-47 quid.
will do that mate, was going to anyway.
Old Mar 15, 2006 | 02:59 PM
cosworth87's Avatar
cosworth87
Thats wery good. so much power and so low on fuel
ekjim
Aug 17, 2015 08:57 PM
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
yawiejon
15
Aug 9, 2015 06:36 PM
