will GSXR600 TB's fit a zetec quick !
Originally Posted by luke89
blacky306mi are r1 bodys splitable so there on there own to space diffrent ?
theres a pic of mine iv since modified the manifold so they fit better they will split like webbers but a couldnt be arsed messing with the linkage.
i also had no space isues with them being on the front of the motor
GSXR 600 bodies are only 38mm
GSXR750 bodies are 46mm at the throttle plate same as the 1000.
http://www.msefi.com/viewtopic.php?t...305b1f921c9c50
Mark
Mark
good post on turbosport about bike throttle bodies on car engines, loads of info and dimensions, diameters, spacing between centres, etc etc seen it a while back but cant be arsed to go looking for it for you at the moment
the economy thing is,obviously when NOT gunning it,is it then the same as before TBs,i dont expect massive increases without using more fuel! i understand the fire triangle! but my new purchase might be needing some of these at some point! but its fairly fast at the mo and economical (40mpg if driving nicely ) and i dont want to go back to 20mpg cruising figures!
big floppy donkey dick
happy to help luke!
i`d guess most throttlebodies will fit provided they use the rubber hose mounted setup!
as said before the bodies need to be 40mm or idealy 43mm IMO for them to work right, just get some big ass trumpets attatched to the front of them
matman
09-09-2015 05:45 PM
