Take 1 wanna-be mechanic+several tubes of Blue Hylomar and..
a perfectly good Cosworth engine and you end up with a serious urge to want to beat said wanna be mechanic round the head with a fookin baseball bat
Removed the engine from my 3 door today as it was a little knocky bottom end. Got another short engine to replace it.
Looked at the seal between sump and block and immediatly knew why it was fooked Removed sump and found at least 1 tube of blue Hylomar floating around in the oil and plenty attached to the oil strainer As a consequence of this pratt the shells are fooked but i think the crank is ok! But all could have been avoided if the wanna be mechanic had used a little bit of restrain when applying what looks like about 3 tubes of fookin Hylomar to seal the sump
Rant over lol
Rant over lol
Boost Builder
Originally Posted by Danny@RADesigns
suprise suprise hylomar appears again
https://passionford.com/forum/viewto...asc&highlight=
Here are some pics i took earlier.
Half of this was in the sump, some of it was wedged between the sump and the strainer and the rest was the only thing between sump and block
Crank doesn't look too bad there were bits of metal as well as blue silicone on the strainer
Shells are fooked!
This ring off No1 was in 2 pieces
Originally Posted by 900ss
wtf peeps use that much i dont know
The builder of that mota deserved to have it blow up on em.
Am i right in saying a 2wd should have a cork sump gasket? Its the 4x4's that don't have one? Or have i got that the wrong way round
This didn't have a gasket for the sump anyway.
you are corret.
2wd cars should have a gasket.
pity the mechanic never knew that.
Originally Posted by Coldo
Excuse my ignorance.. but what it hylomar?
Also, is that literally the remains of a plastic container? And it was inside your sump?
Madness
Madness
Its a shite brand of silicone sealant that everyone seems to buy as they think it is the best mate
Football Cwazy
Madness
Madness
Originally Posted by bud-weis
yeah a 2 piece cork gasket , like on the left of this pic
that's a shocking amount of sealant
rings don't look genuine either??
So he didn't use a cam seal/half moons or a sump gasket
So glad this engine wasn't bought by me! My mate whom i got the car from bought the engine off Ebay about a month ago for 1500 quid and it was supposed to be spot on
Aha, im with you.
So.. how did the tube get into your engine?
The tube wasn't in the engine just its contents were used in place of a proper gasket! When the sump bolts were tightened the Hylomar has squeezed out of the sides and gone into the engine. Bit like eating a vanilla slice lol
Football Cwazy
Aha, im with you.
Originally Posted by pee vee
so how do they stop the sealer gettin into the sump on 4x4 cos?
(apart from not using 2 tubes of it like that joker lol )
Squeeze out a continuous bead along outside of the bolt holes about 3mm round and do not put it on with a trowel
Madness
Madness
