Autronic ignition question (probably one for mark again!)
Is the output on that the same as the fitment on a cossie distributor, looks pretty similar in the pic but im not sure.
Is that the ones that you had problems with then Dave?
If so, i should think with the CDI unit up their arse they will end up as little puddles based on what yours did, lol
I just want to find coils that have outputs that match my leads and work with the CDI unit ive bought off Rod (500R)
Have to talk to mark, i know he likes the single bosch ones but they have sparkplug fitment which means every time i get a set of leads i will have to feck about changing the ends etc, i would much sooner just use coils that work with the leads i can get off the shelf.
Chip They are the correct ones for you to use with a CDI and they fit stock cossie leads, These are not to be used with a dwell based ignition amp as the coils melt manufactors said they work but in relalty they dont like long dwell time.
Mark
Mark
Mark
Mark
Ah right, so i can use them and not get the same problem that Dave had then?
Nice neat little solution that, ideal with the limited space i have in my mini engine bay!
Do you sell these, if so can you PM me a price please.
Or is it a Phil item, in which case, lets hope he doesnt read this thread and spit his dummy out
Mark
Mark
Mark
Originally Posted by Bosch-Man
...i will supply you Chip...i only have a problem with you and not your cash
