Excessive brake pedal travel on a S2
I have replaced the brake fluid with dot 4, the master cylinder is fairly new and have taken out any air from the system using easi bleed but the brakes still dont feel right.
The car has ST170 brakes up front and standard drums on the rear. The abs has also been removed.
Any thoughts?
Bobby
Any thoughts?
Bobby
engine running helps.
The car needs to be level and the back wheels either up in the arches so its on the ground or on ramps OR you get a 2nd person to hold the compensator valves open.
Hope this helps.
Jake
Hope this helps.
Jake
I'll try bleeding them again without the easi bleed and just do it manual.
About 5 years ago ford use to offer a repair kit for the master cylinder anyone know if this is still available?
Thanks for your help guys.
B
B
Update: bleed the brakes again last night but not much joy. I found pressing the brakes for the first time does very little but pressing them the second time the brakes are perfect.
Master cylinder faulty?
B
B
Bobby
I had similar issues on my car when fitting the ST170's and removing the ABS, (got rear disc setup too however)
See if any of these thread's help:
https://passionford.com/forum/viewto...204&highlight=
https://passionford.com/forum/viewto...758&highlight=
Originally Posted by Bobby Singh
Adam thanks for the info ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
I must admit i wasnt bleeding it across so i'll try that tonight. I have done this set up on other cars and its worked fine - lucky i guess lol
