sunroof drain channels(saph cos) Q
after asking on here last night i have found that my front sunroof drain channels are leaking into the front of my car,i jacked the front up and poured a litre of water in the channels so it trickled out of the rear channels no problems.so the Question is can i block the front 2 channels with waterproof sealent so it just runs down the back channels??or won't this work.thanks
the drain chanels normaly have a plastic pipe fitted to them which runs down and out of the cill,are yours still fitted .
you should be able to see them under the car or if you take out the roof lineing
havent looked if the plastic pipes are still on at the front but they deffo are at the back mate.not keen on taking roof lining out for a look
Originally Posted by buftyboy
how mate??
Or you could try an airline on there but don't go mad with it or you may blow the hoses off the channel at the top!!
I unblocked the channels on my girlfriends old Fiesta. I used some plastic rod - I think it's the stuff sparkies use to draw extra cables through conduit...
Just go steady and don't damage the channels
Neil.
Neil.
