Cossie Fuel Pump Relay Inputs?
Does the brown no. 9 fuel pump realy recieve a pulse signal from the ecu, or is it controlled from the ignition?
I have just fitted a new fuse box from ford and my escos will not start unless I bridge a pin from the relay to the fuse (this is exactly the same as the fault that developed with my old fuse box - due to no power to the pump)
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
