200 block kidney box thingy to 2wd sump
i have finally got me 2wd oil pump and pickup and sump to go on my 200 block
BUT the 4wd sump had a pipe that went up to the bottom of the kidney box what do i do with this now as the 2wd sump has nothing ???
also the sensor that bolted on the front end of the sump doesnt fit now either its far to close to the pully any ideas ??
cheers
ahhhh
god damm 200 block to rwd its doing my head in
![Content](https://passionford.com/forum/images/smilies/content.gif)
cheers
ahhhh
4wd crank pulley is bigger than the 2wd one which caused me some ball ache with getting the crank sensor to fit. Ended up chopping another crank sensor bracket up and spacing it out. it looks to me as if the 4wd sump has a different offset of the studs that hold the bracket.
might be crap mind
might be crap mind
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
out of intrest anybody know what i need to do for a power steering pump as the 2wd and 4wd are on different sides and the belts are different 2wd is the old style normal belt but the engine i have is the multi rib belt thingy
i was thinking of maybe fitting a 4wd steering rack and then using the 4wd belt and pump setup ?
Originally Posted by TF Rallyesport
oh and you carnt put a 4x4 rack in if useing a 2wd crossmember.
how much would you want for the bits , if i change the pulleys then my crank sensor should fit ok yea??
cheers again mate
James Porter
28-10-2015 12:17 PM
FlashRS
13
31-08-2015 06:02 PM
lockie
31-07-2015 10:03 PM
