jacking a low car
any ideas on hassle free jacking ? my car is only 90cm from the ground, its only used as a show car but i need an easy way to get it off ground for cleaning and the dreaded puncture. a small trolley jack will only fit if i take the front wheels off and doesnt reach under far enough to go on suspension. the normal ford jack wont work as the side skirts are custom made with no removable panel.
tow bar at the back
but you need 2 small trolly jacks for it
mines very low saff ..jack it under the towbar first ..
then throw other one under side needed
also keep a cube of hard wood if needed for the extra lift
nice idea but i cant put a tow bar on as i have a big custom back bumper .the wood bit may work though although im having trouble finding a jack which gives me enough clearance on the skirts to get it to the suspension .
Sure that most jacks will reach under 90cm
If its mm then something like this will do
http://www.demon-tweeks.co.uk/produc...code=I/C360080
I can sell you one of these for £90
This jack needs just 89mm clearance to get the front 42cm of the jack right under you car. The two jacks I measured for comparison (one 3 ton pro and one 2 ton amateur) needed at least 135mm clearance in order to get under a car.
This jack extends to its full height of 543mm in less than 8 pumps – compared to over 20 for the other Jack in the picture!
Can bring to Bedford if you're there?
Guest
Posts: n/a
Don't ask - I don't know
Originally Posted by gus
yep i use to drive mine onto a couple of bits of wood,
worked a treat
worked a treat
Originally Posted by THE RADMAN
i keep meaning to get one of these aswell,how heavy are they? as you can get the ally ones also
The ones in this thread are 40kg (
) and are rated to 3 tons...
some 1's selling them low entry trolley jacks on ebay
click da link
http://cgi.ebay.co.uk/Low-Entry-Trol...QQcmdZViewItem
click da link
Originally Posted by blacky306mi
i have to driv on to 2 bricks to get a trolly jack under mine the standard windy one only just fits
i dont have a spair so if one goes flat its a recovery job any way lol
i think that the wood planks works well but them jacks look ace
failing that, get your other half to lift the car while u slide the jack under, works a treat for me
he paid £250 for it ..its in blue not sure on the model name
but looks the same as
