Chip, Can you answer some C20LET queries
Basically, is this a load of soup
Performence
Maximum Power approx 392 BHP
Power without Nitrous approx 312 BHP
0-60 in 5.1 seconds, My estimate
Top Speed Achieved 164, estimated 174 Mph
Previous 250 BHP Quarter Mile 13.902 @ 102.9 MPH, 25th Aug 2002
Previous 345 BHP Quarter Mile 14.407 @ 106.73 MPH, 25th Jan 2004 (poor conditions)
Present Quarter Mile @ 392BHP 13.563 @ 108.64 MPH, 31st may 2004
All Drag Strip Events are raced In road trim, ie Standard 18" Road wheels and everyday Road Tyre's
Engine
Calibra Turbo C20 LET 2 litre 16 valve DOHC engine Conversion, Wizards of Nos 80 Bhp Nitrous Oxide conversion, 11lb Stainless steel Nitrous Bottle, Wizards "Maximiser" Digital Progressive Nitrous Controller, KKK Turbo, Race tuned Engine management software, Courtenay Uprated Actuator, Clifford Turbo Timer , Modified Cosworth Head, Pace Inlet Charge Cooler, Wallace Performance 4.5 bar Fuel Pressure Regulator, Bosch Racing R7235-8 Spark Plugs, Arp Rod Bolts, Frontera Front Mounted Intercooler, Bailey Motorsport dual Piston Dump Valve, Z20 LET Injectors, Full Stainless Steel Powerflow De-cat Exhaust System, Hi Strength Silicon Air intake pipe, Oversized Intercooler pipes, K & N Cone Air Filter, Lowered underbonnet Air temperature's, T.F.S Rotor arm, Power Assisted Steering, Powder Coated Rocker Top, Cambelt Cover, Dip Stick, Radiator Fan, Courtenay Polished Alloy Plug Cover and Exhaust Heat Shield. Chrome Engine Strut Brace (OMP), Chrome coil holder, Chrome Brake Reservoir cover, Chrome Battery Cover, Chrome Fuel Rail, Chrome Throttle Linkage, Chrome Alternator Mount, PVD Stainless bonnet lifters.
Transmission Getrag F28 Six Speed Calibra 4x4 Turbo Gearbox Converted to 2 Wheel Drive. Quaife ATB Limited Slip Differential, Helix 4 Paddle Race Spec Clutch and Clutch Housing, Fully synthetic Vauxhall Oil.
Suspension Spax Lowered and Uprated Suspension Springs, G-Max Shock Absorbers front, Sapx Adjustable Shockers Rear, giving approx 80mm Rear Drop and 40mm Front OMP Chromed Engine Strut Brace.
Brakes Wilwood Superlight 335 x 35mm Grooved and Cross Drilled Front Discs Mounted onto Large Alloys Bells, Controlled by Wilwood Superlite Billet Aluminium Calipers, Gsi Rear Discs custom drilled and Callipers fitted to replace original Drums, Goodridge Braided Hoses, EBC Greenstuff Pads.
Wheels & Tyres 8" x 18" Kahn RS-S Alloys with 215/35/18 Ultra Low Profile Pirelli P7000 Tyres.
I just think the figures claimed are slightly 'inflated'
Cheers G
Performence
Engine
Cheers G
Which figure looks inflated to you mate?
Its blatantly someone off Mig, i can tell that from reading the spec "tfs mod" LOL
Its actually a mod me and TFS got off trevor from wizards of nos and he shared with the forum.
the 312 is REALLY pushing it on the standard turbo, but its possible.
the on gas figures seem a bit low, it would be gaining more than that if i set it up for him!
Originally Posted by Shings
Terminals seem low for BHP
If its still in a calibra turbo, i would say they look about spot on.
The figure without Nitrous and has just pump the nitrous figure ontop of that.
Its in an Astra GSi with a half of B+Q's MDF in the boot for the stereo
Yeah you are probably right about just assing the nitrous "jetted amount" on to get the on gas figures.
If its setup properly it should be over 400bhp on that spec
I normally get about 100bhp out of a 75-80 bhp jetted amount on a XE/LET
I'm guessing this is Brens pile of poo... LOL
Yes the power figures are plausable... quite easily infact! But the performance times do not match the stated power, which is where the inconsistancy lies....
And I've noticed its got an ATB diff... oh dear!
At his claimed 392bhp and a quaife diff I've done the same in my car with a hell of a lot less power and an standard diff
Tim, having run with and without a quaiffe diff in a nova with nearly 300bhp, i cant honestly say that on decent driveshafts it actually makes very little difference to it in a straight line, so i cant see it effecting his time much.
Biggest thing killing his times is those 18" rims i should think.
Bet his 60fts are 2.4+
Originally Posted by timrud
Nah, I think he built it himself to be honest?
What colour is it?
What colour is it?
lol, i did sell bren that rotor arm so i guess it is a TFS rotor arm
i have asked many times for people to call it the noswizard mod though (also had it changed on max-boost.co.uk) but people keep calling it the TFS mod for some reason..
rsguy
44
29-09-2015 03:29 PM
