WHICH PIPE FOR BOOST GAUGE????
My s2erst has a boost gauge fitted to the vacuum pipe coming from the left hand side( as u look at the engine from the front)of the pipe coming from the inlet manifold with a t-piece...the thing is ive been thinking should the gauge be fitted to the pipe on the other side the one going to the ecu?, the pipe that the gauge is connected to doesnt go anywhere but only to the gauge as ive got a aftermarket breather system fitted,, any ideas , cheers
Sounds fine to me! The boost guage needs to see boost..... the boost will be the same regardless of whether its coming out of the left or right hand elbow on the inlet manifold!
Hope this helps!!!!
Hope this helps!!!!
Mark RS
12-10-2015 06:01 AM
07-10-2015 12:56 PM
Russ Payne
25-09-2015 08:29 PM
