S2 ERST 2.0ZVH WHAT TURBO????
Ive got a s2erst that i might have to have the turbo rebuilt etc....if i was to get a new turbo what would u recommend???...some pointers on what i want/need
1. dont want loads of power more after a nice power delivery and NOT loads of lag
2. dont want to be destroying gearboxes
want to run 16psi ideally
the engine is a 2.0 zvh, low compression mahle pistons, kent cam/ vernier pulley, 5th inj plumbed in just needs turning on, gas flowed head,front mount i/c,mongoose 3" exhaust,..uprated clutch/gearbox(not sure whats been done to it though!)
will a standrd turbo be ok or would u recommend a hybrid(rebuilding mine if its a hybrid)??
mant thanks...p.p
mant thanks...p.p
Yeah 250hp will destroy the gearbox if its standard, if its uprated like you say, depending on whats been, then should be ok. Just to clarify i'm not saying fitting a T3 hybrid will get you to 250hp automatically just that its capable of running that power ....
T28 not a bad idea if you want quick, smooth spooling. Not so much punch top end...
Im thinking on a nice T3 stage2 hybrid turbo, Turbo Technics have quoted me £500+ vat exchange does that sound like a good price??, im probably gona have a go at fitting it myself
fitting should be pretty easy mate, labour prices these days has to be done
Re: S2 ERST 2.0ZVH WHAT TURBO????
he said he wants NO lag, and not high boost. A T34 at 16psi with his spec will be alot more laggy than a hybrid T3...
Originally Posted by haydenbhp
WHAT YOU NEED IS A T34 HYBRID FROM IAN HOWELL THERE WELL GOOD FOR THE POWER AND COME IN FROM LOW DOWN WITH PLENTY OF TOURQUE.
Agreed,
A T34 doesn't give any more noticable lag than a T3 imo. But mine does come in more progressivly than the old T3, especially on a larger displacment engine like the ZVH.
best thing I ever did was get a T34 with 0.55ex housing. Get a cam matched for the turbo though too. I only ran 20psi and made 288bhp.
Agreed,
Agreed,
JK12
33
26-04-2021 12:09 PM
