Back from Engine Advantages >> DYNOPRINT
Old Jul 23, 2004 | 10:47 AM
  #41
Ian2wdsaffcos's Avatar
Ian2wdsaffcos
Originally Posted by cliff6732000
Originally Posted by Spiky
Originally Posted by DanS
you have a t34 spiky???
yes mate with a .63 housing
Same here
I used to!! Now I got a T2
Old Jul 23, 2004 | 12:28 PM
  #42
CliffRS4's Avatar
CliffRS4
Same here
laaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaag
There's this thing called 6 degree cut back blades Dan
Traction beats pointless wheel spin anyday
Old Jul 23, 2004 | 12:51 PM
  #43
Gavin E-Cos's Avatar
Gavin E-Cos
Jo, did you see my car there? K99 RSC
Gav
Old Jul 23, 2004 | 01:38 PM
  #44
Billabong's Avatar
Billabong
Which doesn't help lag .........
Old Jul 23, 2004 | 02:04 PM
  #45
Jo's Avatar
Jo
Gav
Yes mate.
I was nicely parked inside
Wanted to ask you about your S.E.C.S monitor anyway...
I saw you installed it where the clock used to be.
Can you buy those "plates" where you put the monitor in or did you make that yourself?
Old Jul 23, 2004 | 02:05 PM
  #46
turbinator's Avatar
turbinator
Default Re: Back from Engine Advantages >> DYNOPRINT
Originally Posted by Jo
So...
After a 17hour trip to England for my stage 3 I still don't know whether to cry or laugh
Started out this morning with 237.9BHP@5691 rpm and 310.6lbft@3625 rpm...
Installed all the stage 3 goodies and raised to boostlevel to 21.7Psi held.
Back on the rollers...
Surprising result... In stead of the "normal" 330BHP, it just went up to 285.5BHP@4524 rpm but the torque however raised to 361.1lbft@3678 rpm.
After 4524rpm turboboost drops really fast...
Now Paul thinks it might be the turbo so he's gonna rebuilt it.
I hope the problem is fixed then...
Must say Paul is a top bloke
I'll scan in the results tomorrow, 'coz I'm just to tired at the moment
you dont need a rebuild.. only a different exhaust housing..
its too small to have power at high rpm .. but gives you boost at 2000 rpm.. thats all you need to do!
if you still have the same exhaust housing on it that it ofcourse
Old Jul 23, 2004 | 02:10 PM
  #47
Jo's Avatar
Jo
It's still the same exhaust housing...
Which one should I put on then?
Old Jul 23, 2004 | 02:18 PM
  #48
turbinator's Avatar
turbinator
0.63 ... sell the 0.48 to someone with stage 1
Old Jul 23, 2004 | 02:21 PM
  #49
Jo's Avatar
Jo
Ok, thanks
Old Jul 23, 2004 | 03:08 PM
  #50
Gavin E-Cos
Jo, thanks for the pic!
I have just spoken to Paul, my car made 308bhp & 312torque, so im happy
SECS monitor, I made the plate myself although its looking a bit "rough" now as its been in and out a few times.
Did you also notice were I installed the clock?
Gav
Old Jul 23, 2004 | 03:33 PM
  #51
CliffRS4's Avatar
CliffRS4
What do the cut back blades do then, I won't pretend that I am in the know as I'm not.
The turbo isn't laggy at all , but do tell me what part the cut back blades do play then?
Old Jul 23, 2004 | 03:54 PM
  #52
Jo's Avatar
Jo
@ Gavin : yep, looked factory fitted like that
Old Jul 23, 2004 | 04:00 PM
  #53
Gavin E-Cos
The clock is very slightly bigger than the hole, so was quite hard to squeeze it in!
Hope you get your car sorted Jo, im picking mine up Saturday. (and cant wait)
Gav
Old Jul 23, 2004 | 04:13 PM
  #54
Jo's Avatar
Jo
Gavin E-Cos,
I know what the 'problem' was now.
Just have to replace the 0.48 exhaust housing by a 0.63 one and it should be fine.
Still will have to go back for another dyno run then
Old Jul 23, 2004 | 04:17 PM
  #55
Gavin E-Cos
Mine has the .63 housing on, and I was thinking of changing it for the smaller .48 one, but im not sure I should now!
Maybe I will go for a .55 one.
Gav
  #56
Jo's Avatar
Jo
Here are some pics of my car on the dyno:
Paul doing his stuff
Old Jul 23, 2004 | 04:19 PM
  #57
Gavin E-Cos
Old Jul 23, 2004 | 04:25 PM
  #58
Jim Galbally's Avatar
Jim Galbally
woulda thought even a .48 would make more than 280bhp?
as for cut back blades, i was under the impression they were there as a safety precaution incase the blades touched the housing when pushed beyond the turbos limits...
however its quite possible that thats pub talk bollocks as i cant rememebr where the hell i heard that said...
Old Jul 23, 2004 | 04:28 PM
  #59
Jon ERST S2's Avatar
Jon ERST S2
oh dear...
do a search back for someone being ridiculed for saying that.
AFAIK it's to reduce back pressure is it not?
then again *I* could be wrong...
Old Jul 23, 2004 | 04:31 PM
  #60
Jo's Avatar
Jo
I hope i don't lose my torque figure if i put on a bigger exhaust housing
Old Jul 23, 2004 | 05:06 PM
  #61
Spiky's Avatar
Spiky
jim, a t34 and 48 housing
will make more than 280
you will get around 340 vrey max 330 should be ok
Old Jul 23, 2004 | 05:15 PM
  #62
Jo's Avatar
Jo
Spiky,
sure about that?
how much can you get with a 55 housing
Old Jul 23, 2004 | 05:25 PM
  #63
Spiky's Avatar
Spiky
i made 348 with std comd and .63 & 21 psi
mate had low comp .48 and ,made 345 at 24psi
on the same day
stretch on this board is today have his mapped live and has low comp head work and .55 housing and loads of boost, and is hopoing for 380-400
mapping head work makes all the difference
Old Jul 23, 2004 | 05:30 PM
  #64
Jo's Avatar
Jo
Mine is still standard comp, so i guess i'll just have the turbo rebuilt and a 0.63 housing put on
Old Jul 23, 2004 | 05:37 PM
  #65
Spiky's Avatar
Spiky
it should have a .63 already.
so just get the seals and bearings done...and off you go
Old Jul 23, 2004 | 05:39 PM
  #66
Jo's Avatar
Jo
it has a 0.48 at the moment, it's a hybrid turbo
Old Jul 23, 2004 | 05:41 PM
  #67
Billabong's Avatar
Billabong
Cliff, the cut back on the blades is basically to slow the turbine down a touch, to prevent overspeeding & other issues.....
IMO, .48 housing on the back of an EsCos turbo is fine for stage 3 - certainly wouldn't restrict you to below 300bhp.......
Old Jul 23, 2004 | 05:54 PM
  #68
Matt's Avatar
Matt
torque seems impossibly high for a std engine (i mean head/cams/comp) with a t3 turbo, let alone it making it at that boost
i thought cut backs are to decrease back pressure and reduce the associated heat, fook knows, mine (exact same minus the gay bits he has lol has same engine/turbo as stretch's) has a 7 degree cut back ex wheel anyway LOL
bill, my cars is hardly laggy
Old Jul 23, 2004 | 06:04 PM
  #69
Billabong's Avatar
Billabong
Matt, I'm sure it isn't
My point was that cut back on the turbine blades isn't there to reduce lag.....my original reply was a quick reply and maybe too cryptic....I also think you're probably correct about the back pressure too (overspeeding the turbo will I think increase back pressure?), but my memory is sh!te at the moment.
Old Jul 23, 2004 | 07:09 PM
  #70
Jo's Avatar
Jo
Except for the 4 layer head gasket engine is indeed standard...
I didn't mess with the resultfigures... You can ask Speedy G, 'coz he was there with me or Paul himself
Old Jul 23, 2004 | 07:18 PM
  #71
DaveEscos's Avatar
DaveEscos
let me guess.. you didnt copy a certain someone and put it in the right side air vent?
Old Jul 23, 2004 | 07:44 PM
  #72
Andreas's Avatar
Andreas
My T34 0.48 is set to 24,5-25,0psi and this it holds up to 5500rpm.
At 5800 its 24psi and at 6400 its tailed off to 23 psi.
Old Jul 23, 2004 | 09:54 PM
  #73
Gavin E-Cos
Yes risht side air vent, although I dont think I have copied anyone.
I had one of the first if not the very first Escort Cosworth SECS monitors. So early infact that Simon had not finished the software and my first one wasnt set up for a 2.5 bar MAP sensor!
Gav
Old Jul 23, 2004 | 10:06 PM
  #74
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Dave,
Looks like you copied Gavin . How does it feel to be beaten to something by a country bumpkin .
Old Jul 23, 2004 | 10:08 PM
  #75
DaveEscos's Avatar
DaveEscos
think NOT
Ill happily compare installs against you both
norfolk numptys
Old Jul 23, 2004 | 10:14 PM
  #76
RichardPON's Avatar
RichardPON
I can confirm about Gavin's monitor, cos he and I had one about the same time.
That was many moons ago now!
Old Jul 23, 2004 | 10:19 PM
  #77
nomad's Avatar
nomad
jeez , why sell the 48 and get a 63 ?
did you mention you had side to side play ?
how about forward to back movement ?
Old Jul 24, 2004 | 08:33 AM
  #78
Gavin E-Cos
Thanks Richard.
Im not sure I should thank Mike for his "bumpkin" comments
Dave, we both may have done the same thing at the same time, but I know I had one of, if not the first one for Escort Cosworth and changed the location as soon as I had it.
As I said my install is not looking its best now. I want to make up something new but havnt the time at the moment.
If youve got any pics I would like to see them.
Gav
Old Jul 24, 2004 | 08:50 AM
  #79
Jo's Avatar
Jo
there was no forward to back movement at all , just alot of side to side play
Old Jul 24, 2004 | 09:09 AM
  #80
turbinator's Avatar
turbinator
Gavin E-Cos,
Jo, had a look at the dynosheet, (didnt before)
but have to say.. the boostcurve looks bad.. cant possibly be only the exhaust housing when I look at the curve.
it should boost up to 5300 then slightly drop a bit , not the way yours looks thats dropping after 3750 rpm...
so maybe a rebuild
