Had fuelling set up...melted a piston on the way home :(
#121
Speaking as someone who understands engine tuning.....
If it is a known problem that turning the fuel pressure up could potentially
cause a problem then why was it turned up without advising the customer
of the potential problem ?
Surely, low fuel pressure on a car is a sign of an potential future failure
and any adjustment made is only masking the real issue.
#122
just finding my feet
I find that VERY Very insulting, school boy error you fucking twat
I havent melted anything.........................
does low fuel presure not indicate there could be another problem in the fuel system like a leaking regulator/worn pump ect,,,,,,,, as i said i dont know so hence why i asked
you are NOT the sole reason if failed,,,,,,,, the pump was,,,,,,,,,, BUT checking it at the time could have saved a engine,,,,,,,,,, but if the AFR was spot on after then you wasnt to know
just is DID fail when not ragging it seriously,,,,,,,, we have not posting saying "scc set my car up and it melted cause they set the fuel presure wrong"
just that i feel you "could " have missed a hint that theres another issue
#123
simon WOULD that give the impresion there could be another issue,,,,,,, remember that the car was running fine for a year and never melted when we thought it would have,,,, and it was just bad luck it had a failing pump when going SCC and there tweeking caused it to fail more
but would it not sugest another problem,,,,,,,,,, not to mention the reason for you to fit a fuel presure gauge on the new secs monitor when it comes out
#126
then stop typing and get that dam montior done
my car will be finished sooner than i hoped as im gonna be sorting a engine for simon now and so i may aswell get the cossie done
the offer is still there to buy one AND test mule it,,,,,,,,, and any issues aslong as i will just ask about em and not use your name as slander as im seriously not a moany person
#128
Well if was me i would have been asking what could have caused the fuel pressure to drop, to need turning up in the first place
mate i aint got a clue about techy stuff,,,,,,,,,,,,, i only know how to use a dremel, cold chisel and a club hammer im afraid
#129
we aren't talking about a std FRST are we its a MFi block and MFi head with EFi management from a FRST and an external Cossie fuel pump, which had never had the pressure setup from the day it was put together (was going to put "thrown together" but felt it harsh ) so how was anyone to know that there "may" have been a pump problem????
Now had it have been a std FRST with std pump etc it "may" have pointed to a problem...... but how many posts have you seen over the last few years " which way to turn my fuel pressure up". Imo checking and adjusting the fuel pressure is just part of a tune up and I wouldn't start checking volts etc etc as Imo this isn't unless actually asked to do so
Just my 10 pence worth
Steve
Going back on the fence now to watch..... Tiff wheres them HobNobs
#131
Originally Posted by Rob@SCC Performance
How do you know the pump HAS actually failed
but fair comment,,,,,,, i AM jumping the gun,,,,,,,, it could have been a injector failing as they will need flow testing too,,,,,,,, just im going by the basics that low fuel presure and melted engine shows either presure reg/fuel pipes tp small diamiter ( remember this is a converted car thats normally carb powered so thats only fair to check too)
its the converstation you said about failing fuel pumps and people using xr2ipumps on there rst conversions that keeps bringing me on to thinking that
#132
steve thats a fair coment BUT the fuel presure had NEVER been touched from the factory as rob can confirm,,,,,,,,, as that was hes reason to tweek it
BUT a check of why it could be low would feel a good choice imo
bit like turbo failing and fitting a new turbo and not checking the oil return or even the feed to test if its bloked
just change the problem and refit,,,,,,,,, hope you see where im getting
how long would a test of the failing fuel system take during the set up,,,,, who would refuse paying a extra hours labour if that was checked
remember thats the reason WHY it was taken in
as for the mfi engine converted,,,,,,,,, steve it worked FINE and never melted in 4k,,,,,,,,,,, NEVER melted in 4k and the only problem was the idle speed valve issue
#133
Steve_B,
Fair enough didnt know that. accepted with grace.
Ginge,
Only one way to find out, take it apart, rebuild it and retest EVERTHING thoroughly.
Ginge,
wasn't a pop at you or anything, just thought that everyone should know the facts that is't not what you'd call a std engine build....
The only way anyone will know is to rip it apart, find the problem and then look for the cause because atm its all guess work until the heads off the car at least..... So Ginge pop outside and we'll see you back in 30 minutes to tell us what ya found when the heads off
#134
Personaly with the getting hot and smoking can say with personal experience that happens with head gasket, dont know if Rich still about, but do u remember mine the first time we met up the Pod
And the time when i finally killed my engine, couldnt see the A1 for mile or so lol, and that was just with slowing down, BUT what I did happen both times is it wouldnt start due to Auqa summit or other, basically bores filling with water from the system causing to much compression to even allow the engine to turn, but spose the "smoke" comming out the back (which smells) is actually steam from the water in the combustion, maybe lol
Edited (auqa lock is the thing I think )
#136
i can pop outside but the cars in essex,,,,,,,,,, i dont live near him
it wasnt a standard engine but the failure IS a normal failure and looking at what was actually touched hints to the problem imo
taking the head off is ALSO pointless as then engine is CLEARLY fooked,,,,,,,, take the head of to see that its melted number for is the same as the last time i said hes melted the engine as a garage sugested the valve steam seals need changing and sold him a set of them,,,,,,, even though compression on 2 and 3 was 30psi they said the steam seals where prob leaking badly
its fooked,,,,,,,, moaning aint gonna solve it and its NOT fooked just cause SCC touched the car,,,,,,,,,,,,,, they may have missed a bit though
#137
rapid one,,,,,, theres cream for oil in the rocker cover and pouring out the breather when you turn the car over and its dark blue smoke ONLY and when you back of theres a HOOOOOGE puff,,,,,,,, started as a small puff and when its COLD the engine dont smoke straight away,,,,,,, but it starts and gets worse,,,,,,,,,,,,,, oh and it done this before and melted 2 pistions the same way
its melted on the outside of the pistons i belive but unless i can be arsed to take it a part to check we may never know
and cossie pumps DO fail
#138
Originally Posted by b19bal
Steve thats a fair coment BUT the fuel presure had NEVER been touched from the factory as rob can confirm,,,,,,,,, as that was hes reason to tweek it
FRST Fuel pressure 2.9 - 3.1 bar (43-46psi) with vaccum
Cossie fuel pressure 3.2 - 3.8 bar 47-56psi)withOUT vaccum
"Above taken from Autodata"
#139
Actually to be fair (although no one other than Rob named names, probs cos he was happy he did the correct job) think u do now owe it to SCC to remove the head and find out what has actually happened
Also could not making the car run well, have caused a failing gasket to finally give and blow, that an old falicy with nitrous, aint the nitrous that damages an engine it just the engune isnt strong enough for the job in the first place
#140
what size are the fuel lines etc?
there isn't any mileage in it for example the return line is too small and upping the pressure could of affected pump performance at the injectors...
id be gutted in the same circumstances - but you have to look at it from the other side - its a converted car - NOTHING on it is known to be good by the tuner at the time.
Ok he had the money to do further checks etc - but before buying the actual 'service' of a tune up - was it discussed or even considered what he would be getting for his money.
when you ring the AA because you've had a puncture, he fixes it and then the wheel bearing fails - you don't go hunting the AA man down do you?
#141
PassionFords Creator
Wow... what a cracking topic
Some points, if anyone cares, and in NO particular order...
1) For Ł60 i wouldnt even have checked the AFR with my wideband.
2) The COSSIE pump does NOT fail if you up the pressure.
3) Even if it wasnt a cossie pump, Rob upped teh pressure back to STD. I plainly said upping it from OEM caused the problem. Every time you show her boost the fuel pressure rises chaps
4) Why did the pressure drop? Well... was the cap missing from the top? If so, it dropped cos of an idiot fooking about is most likely. If it was untouched, probably simple fatigue. Its a simple spring in there, just as likely as an actuator to soften with age.
5) Mayo - check turbo? As SCC do and obviouisly you DONT know, its not uncommon for the core to splut and introduce water into the oil. The result can be a dead turbo and lots of oil in your water. Id have checked it too.
6) Mayo - Melted? It is NOT common for a dead piston to put mayo in the oil and im not sure why you all think it is? This is more commonly a headgasket problem, as SCC said at first.
7) I hope you like humble Pie if the fooking headgaskets failed.
#143
#144
But No. 6 deffo sounds right in my eyes
#145
The word I did think I knew I got wrong, maybe I'd best just move along to the muppet room where my expertise would be of more use
#147
i seriously cant be arsed to remove the head i cause it is a melted piston,,,,,,, would rather just fit another as its quicker
and as said this post was to get ideas and NOT slag off SCC,,,,,,,,,, as id like to think im above that,,,,,, considering I recomended him to go there rather than to another place local to his house cause most of my mates are friends with rob and the rest of the crew including one of my closest mates hence why i never posted the name,,,,,,,,, now rob HASNT over charged us and so MAYBE hes setting up is in different stages,,,,,,, could even be he charged that as at the time there was soo litle that looked like doing,,,,,,,,,,, im NOT slagging him off NOR blaming him for ANY failure,,,,,,, just wasnt sure if low fuel presure would hint to check more that tweek the regulator,,,,,,,,, i remeber you checking my mates 3 door before stu and that had a fooked regulator,,,,,,,,,, aswell as other issues
60 quid does seem somewhat cheap too,,,,,,,,,,,, when i took my car to you stu the bill IN TOTAL comes to over 400 quid just in fuel and feeding switch ect on the way,,,,,,,, but i pay it as i like the fun drive
btw stu when the engine IS back in the cossie and i book my car in i would like you to add 2 hours extra labour checking that the engines not back to front ect,,,,,, as i would prefer for potental problems to be mentioned IF ITS POSSABLE TOO !!!!!!,,,,,,,,,,,, now after reading robs replys now it seems that he done what he could and dont check what others may in hes set up
so its simple crossed wires as to what job is what i guess
still cant be arsed to remove the head
#148
also... another hours labour on a Ł60 bill...... and no one would grumble?
don't know how much you work for - but an hours labour and overheads and i'd grumble if they said... oh yeah i've just checked this extra bit - we hadn't agreed to but the bill is 50% more now
#149
I have had the same experiance before with the mentioned company my car went in for a new turbo and erst lsd box to be fitted.
came out the same day headgasket went
went back in for repair
on the way home from picking the frst up blue smoke billowing out everywhere
piston broke!!!
went back in for a full re-build i asked for forged low comp pistons to be fitted, came back with standard zetec pistons and skimmed to lower compression (zvh) annoyed me greatly as i specifically asked for FORGED pistons to be fitted at WHATEVER COST ( they said the forged ones are overpriced and these pistons would be up2 the job)
following a strict running in period it went back for 'setting up' a week later only to FAIL once again on the way home
was then rebuilt again FULL CHARGE TO ME after my car has broken so many times upon leaving this place on the same day and left runnin only 10psi boost from its original 15 it was running being told it will just BREAK AGAIN IF I up the boost. so why wasent i told this from the beginning to stop all the HEARTACHE AND WALLET BREAK.
all those rebuilds for nothing
i got to another 'ford tuner' who tell me that skimming pistons is the most stupid thing to do as it weakens an already weak standard piston
either SCC's equipment needs calibrating or maybe they need some more experiance
attitude was also, turbo engines are unreliable so get used to it
carl
piston broke!!!
carl
#150
but tbh the WORST thing yesturday was the alt wire on me cabrio got cut on a speed bump and the AA didnt know how to wire it up and ust said the wires aint from the alt,,,,, ive jumped started you and the cars running now,,,,, enjoy
so there are WORSE things tha happen in life
#152
"attitude was also, turbo engines are unreliable so get used to it "
must admit thats the part i wasnt a fan of,,,,,,,, but has to be said that wasnt a comment from Rob
after reading your post makes me think that a mule engine to die aint a bad thing,,,,,,,,,, i just liked being the one that bodged a engine that can beat me mates scooby P1 off the lights
#153
500 quid?for a 60 quid setup? fookin christ ginge,id take 60 notes and a can of coke!
fuel economy going back was no the 50 to 70 miles to a tenner i was promised though ,,,,,,,,,,,,, but switch drove back and we NEVER went below 130 , we left at 530 and dropped max of AND stopped for fuel,,,,,,,,,,,,,,,,,,TWICE !!!! and got a quick munch and still got switch home in time for his meal with his missus at 830pm
AND IT WAS RAINING
could feel the difference in the car though,,,,,,, seriously recomend it to anyone
#154
mind you,i did once take my car to scc for a check to see why it wouldnt start,ended up spending the thick end of 5 grand there! oh dear,those were the days,remember walking in with 3000 in cash to pay for a job! top work tho,NO complaints!
#155
speeding on the roads again in the wet??
ginge ffs - youre always ranting on about it being dangerous etc etc.... road clear all way back from blackpool at 5:30pm are they?
#156
Mmmmmmmmmmm Ok....
My word the two nightmares in the 5 years ive been self employed are in the same thread....
As i recall it (was some time ago !!!!)
I couldnt help that im afraid - batt's in crystal ball were flat
As i recall your Dad was paying and he wanted it back on the road a cheaply and quickly as possible - we removed the pistons (wasnt quite a full rebuild was it now ) and sent them to be matched up as ZVH's aren't our thing - the new ones were the same as the old ones as requested by your Dad if i remember rightly as the cost was MUCH MUCH cheaper....
As i recall YOU told us what boost you wanted to run....... it wasnt our conversion after all, i seem to remember the previous owner had all the work done before you bought it....
you paid for the parts only if i remember rightly- seem to remember it cracked a piston
Cause you wanted 15psi !!!!!!
I recomended you got it properly mapped if you wanted it to last !!!!
in the end your Dad told us to do what we thought best.... so we did.
You need to speak to the person that specced the engine im afraid....
Calibrated frequently......
We all need more experiance im affraid.... No one knows everything
Sorry if you got that impression
Rob
piston broke!!!
piston broke!!!
Rob
#158
Well thats my Dirty Laundry Aired....
Weve had over 10,000 cars in for repairs etc in the last 5years (well weve done over 10,000 invoices now....)
and weve had a very very small handfull of complaints - very low % so i hope everyone see's this pointless drivel for what it really is
#159
i have a complaint rob,its a bloody steep hill to get to the pub for a lunch when the car is in there,could you not move somewhere less hilly?and the junction to the road? try getting out of there at rush hour in a 400bhp cossie with no handbrake and a violent 4 paddle clutch!
#160
