Had fuelling set up...melted a piston on the way home :(
#42
Originally Posted by XRT_si
shings if they turned up the presure would that not then check the pump though, saying theres no way of knowing it would fail 5 mins up the road to a extent that totally melts down the engine under normal driving is not like it failing under load though
thats the part im questioning, as for the price of the set up thats irelevent too as i paied for a cars fueling to be checked and it melted 5 mins later
dont mean to sound arsey btw as i really cant be bothered to fit another engine and feel that if i ignored it i would still have a car running 1/2 a bar under fuel presure but never failed
just getting a idea of what people think as im sure if this was a cossie then more questions would be asked
its not a old car with old wiring aswell, its a converted car thats had new wiring on the pump but i could still be a design problem with the conversion hence me getting infomation of what to check first
The price is relevent- You get what you pay for in this world.
#45
Originally Posted by b19bal
shings i think thats a bit unfair to be honest
the engines MELTED its not failed, the fuel pumb would get worn and flow less surely and so that would idicate a problem, for it to melt driving home and not racing tells me theres something else there
he also got told the injector COULD have got a dodgy spray for a moment and would have melted the car,,,,,,,,, thats again not on a high speed run but driving on a 40mph road with 2 roundabouts between em
im more wondering about the fuel pipes and the fuel pump but to fail and that and NOT when it was being set up ( ie being ragged whilst looking at the fueling) makes me wonder
the turning up the presure as its low and the car to fail just sounds strange
maybe its just me but surly a set up for checking fueling would include checking the pumps flow ect ( btw they may have done that so not saying they havent )
getting a car back that was inn for a MOT and then the cam belt lets go is bad luck,,,,,,,, get a car back from having a brake test and the brakes fail and cause you to crash is more what this is like tbh,,,,,, would you not wonder then ?
Pump
Wiring
Injectors
Chip
Fuel pressure
Hoses
Fuel filter
Also how was the fueling checked on boost?
I need to make it clear as well I am not being arsey or owt either- I am just looking at it from another point of view from the owner who is obviously a bit pissed off and looking to blame someone.
I would honestly put it down to bad luck- as his sig says Zetec turbo coming soon.. so putting another engine in isn't that much of a problem.
Jake
#46
ginge,i meant by someone else,someone independant!crazy fool,my brother has just spent months waiting for his car backafter using a "reputable" company to fit a new engine,turns out,after 3 trips to them looking at it,finding nothing,then going to another company to independantly check things,that they had fitted a head gasket from a different car(unknown,however,it didnt have enough holes for the coolant! ) this then broke the heater matrix etc etc..... so i would suggest going somewhere else to check all possibilities then making an informed decision.
#49
Originally Posted by Patto
anyone else know wot ofab/c stands for..?
OFAB is voltage sensing from the map sensor and OFAC is frequency from the map sensor.
different ECUs and map sensors and not interchangeable.
in terms of set up have they just altered the base setting? or done an on the road test for it?
#51
Right....
Having just seen this post i thought i may as well give the facts....
We carried out the Tune up on this car today - when it came in the car was running pretty badly - carried out a standard engine tune.....
Checked plugs idle co etc etc
idle Co% was very very lean so we checked the fuel pressure which was about 1/2 bar too low - hence we adjusted it to within spec.
The idle was hanging high and we checked that out - checked TPS voltages as they do tend to go down on these, as all ok - we removed the idle valve and cleaned it out, idle was still playing up but it was getting a signal to the valve from the ecu - so it looked like it was a management issue, we unplugged it to make it more stable (prior to this it was int sticking at 2000rpm!!)
The boost wasnt touched as we were told that it was set to 16psi as recomended (although we did test it with our own calibrated test gauge and it was spot on)
Pat gave it a run with the wide band up the exhaust and it def wasn't smoking and the fuelling was fine when tested,
We called it a day at that - didnt want to get too involved with the idle issue at that point as i had only quoted you for a Ł60 +vat tune up and that would require more investigation....
I gave it a quick run to the roundabout up the road and back and it was fine......
also you told me you got to the M25 - thats a tad further than a few miles..... and you need to go down a pretty long dual carriageway to get to it.... ive had my own cars at twice the speed limit and some down there !!!!
I'm sorry if you think i wasn't very helpful when you came back, but when someone comes in giving it the "what you done to my car" - "it was fine before you touched it" bollocks it kinda gets ya back up when you know you've done the job properly !!!!!
Like i said to you - i dont know whats caused the problem, it needs taking apart and looking at, but were not to blame, we checked what we could !!
Regards
Rob
Regards
Rob
#52
Norris Motorsport
Well put Rob, sounds like you did exactly as I would have done!
I know I joked about it in an earlier post, but really OFAB/C managed cars usually do melt in my experience!!!! SHONKY SH!T!!!!!!
#53
sounds like it was a underlying problem that was there before . im saw scc did there job perfect as they alway have on my cars ive never had a problem with any work they have carried out and im sure i wont in future
#54
#55
As regards shonky OFAB/C management, yeah it aint the best however i never had any probs with mine nor really no of anyone else havin any probs with it and mine was fucked with a few times lol
Could be bad luck though regarding the melt down but i wouldve had a complete system check if i thought anything was at fault not just a drive in drive out quick tune
#56
Originally Posted by Rob@SCC Performance
Right....
Regards
Rob
Regards
Rob
#57
sounds fair enough to me Rob, you just happened to be in the wrong place at the wrong time today by the sounds of it!
Those people saying Karl is wrong about ofab because there car is ok on it.
If you have owned 2 cars on it and they are both fine then i guess you would view it as ok, but if you tuned 100 cars on it and 20 blew up despite the fact you KNOW they were properly setup and its just that management isnt up to the job, then you would view it as shonky.
So personally i would take a lot of notice of what Karl is saying, just cause your car hasnt gone pop yet doesnt mean its not going to!
For a well respected tuner to turn his back on a particular type of management and refuse to touch cars with it again, despite paying customers wanting him too, you can pretty much be certain there must be a genuine problem with it!
#58
not just Karl.
I'd heard locally that turbosystems had stopped dealing with FRSTs aswell.
not sure whether it was down to management issues or just because tony doesnt like Fiesta drivers lol
only rumour though.... potential customers please ring to check!!
EECIV has in my experience chucked a few wobblers for no apparent reason before, and then ran seemingly fine with nothing else done to remedy the problem other than leaving it! lol
#59
Just an idea but have you checked your alternator voltages? My alt. started to die and the car dropped fuel pressure and ran leaner and leaner in a matter of miles, thankfully it was being live mapped with karl at the time and his warning device picked it up which is why its still in one peice, but it could have been a very different story!!
Just an idea anyway.
#60
PassionFords Creator
Sorry to read of your troubles pal.
As i map and sell a lot of Ford EEC IV "OFAB & C" systems i guess i best now comment on a topic i would otherwise have left alone and just offered advice to the unlucky owner...
For the record, we have built, setup and mapped literally thousands of ecu combinations using both OFAB and OFAC management and NEVER had any meltdown issues that can be put down to a basic management fault.
They are both, in my opinion, the most basic of Speed density systems in as much as they have only crank, air, water, throttle and pressure inputs and run in teh batch fire configuration, making them somewhat less quirky than a sequential system like Marelli as the Injector timing isnt as prone to phasing error.
However... due to the simple fact stated above, they are what can be termed as "Quirky" as the map needs to be totally correct for them to run right and fuel safely, but hey, that is NOT the managements fault now is it. They also have a quirk with idle stability that requires 100% perfect TPS alignment and base idle setting (Some peeps swear it hasnt got an idle bypass screw. lol)One of teh reasons it has this idle issue is the injector alignment to the intake valves is poor and quite irregular, but once we have some airspeed, its NOT a problem at all and the system returns good driveability, economy and power.
A common issue with these systems, as allready mentioned, is going above stock fuel pressure spells sudden death to the fuel pump seals and often the engine, but again, hey, why would you want bigger than stock pressures? Fit the right injectors you cheapskate..
Finally:
Due to Fords security and way of doing things, i only know of 3 people in the UK who can truly map these systems out on the road live with an Emulator and get results. Many tuners say they can and then just throw chips in and out hoping for the best, and its often not until the owner sees real hardware emulation equipment hooked into his car that it dawns on him his cars at yet another tuners because it was never mapped live to start with and thus problems with ofab & c rumours "Even when live mapped" begin to circulate.... lol
Take care out there...
Finally:
#61
Stu, you write tech stuff (as above) just like Gerard Sauer (spl) did years back in CCC magazine.
You make things VERY easy to understand, there is an economy of words that gives the topic a clarity that actually makes it a joy ro read! I see a career in journalism just a few phone calls away
#64
I definately agree that Stu should be writing for fast ford magazine, drop simonFF a pm and ask him mate, he will rip your fooking arm off i expect, and the publicity cant do you any harm from a business point of view surely?
#65
Right as i stated already this is not a blame post, i was asking what could have caused this and what would have been checked.
The car did 100% start to smoke within 2 miles. I got to the M25 (over 2 miles away) thinking it would clear, it didnt, it got worse.
Thanks for the suggestions but no wasnt the alternator, i have a voltage gauge.
I chose EFi as i was under the impression it was a much more modern system, and iam certain the chip/OFAB had nothing to do with it as the chip has been running on the car for a long time with no problems.
Stu, thanks for the info, and i am beige injectors by the way
I assume as stated above that it was just bad luck that upping the fuel pressure caused the pump to fail, one of those things it seems.
#67
And following on, Stu would the fact it had a very funny idle cause problems? It ran with the bad idle for a little while now, and when the ISCV was disconnected the car wouldnt run properly E.g. Seemed to be more hesitant boosting up, and oil light came on occasionally, all of which disappeared when it was plugged in.
#68
Thanks for the kind comments about my writing everyone, very kind of you indeed, and i am thinking quite seriously about it as i type.
Chris, there are no common faults other than irregular fuel pressure that can create the idle issue that are also related to fuel or spark levels upon WOT so its unlikely pal.
I presume this engine was a nice simple 1600 CVH with Beige injectors, bigger cooler, T3, sensible camshaft and 1.1 bar of boost with one of my custom off the shelf chips? If so, a walbro pump will normally maintain an easy 11.5:1 to the end of brunters and back time after time after time, its a well trodden path indeed.
What does cause issues with the Fiesta is engine cooling.. the bays are horrible for airflow and the whole system needs to be in tip top condition to avoid excess temperatures.
#69
Football Cwazy
my old car suffered with an irregular idle that was traced to a worn cam shaft.
Many many FRST's suffer with bad idle, ( go on fietsturbo.com and search 'idle' , see how many posts come up )
is the ISCV controlled in relation to throttle position? if so what effects will there be on overrun with it disconnected? presumably overfuelling due to less air coming in?
#70
PassionFord's crazy fool!
#71
Guess that wouldn't help at all on a blast down a dual carriage way.....
#72
#73
#74
0-60 in 17 seconds (eek)
I appreciate that at the end of the day, it's the owner's decision as to what to do, where to spend money, etc... But if there's a serious danger that the management won't be up to the job, would it not be better to turn people away in the first place rather than be blamed for something that's not your fault in the first place ?
Not a dig, and I did read what Stu said, just wondering if there isn't a case for saying enough is enough sometimes
#77
Originally Posted by frog
Karl doesn't, I was asking Rob I guess
#78
Originally Posted by rsnissan
Rob was agreeing with Karl in as much as "doing what he would have done" not that he would not touch a car with that management
#79
i could be wrong here but if you've done a compression test and got 20psi then surely the piston hasn't melted?
i'd be inclined to investigate head gasket failure from what you have said.
#80
Maybee the damage was allready done mate....
How long had u used the car for without a proper setup ??
My mates had a fiesta turbo, which he had set up, he had bigtime fueling problems at the top end and it ended up melted, oil in the breather system tells me it could be gasket failure and could possibly be bad timing and very unlucky.
I hope you get it sorted
