No power to the fuel pump. 2.0l dohc
I got no power to the pump. The pump is working when i put 12v on it. The fuses are ok. Also the button in the trunk. What can else can i check. I have check the wire from pump to fuse nr 23. Its ok. This is my fuse box is everyting on right place. Bought it this way. Its a 1992 2.0 dohc 4x4. Sry for my bad english. Regards robert
I think on the Cossie the switch is a negative output from the ECU. It may be worth adding an earth to the pump as a test and then track that back...assuming the other Sierra's are the same?
Check the inertia switch, dependant on year you will either find it in the spare wheel well earlier cars or behind the front footwell trim under the dashboard
Resident Wrestling Legend
If it's a final facelift 92 spec with the smooth dash and square fog light buttons it will be in the foot well
the boot mounted ones were in the 89 spec cars
The other issue I've seen and fixed was the loom to the rear number plate lights, it's shared with the pump and if it's corroded can cause the same issues
jonesymk2
11
19-01-2008 05:16 PM
mitchrst
13-12-2006 01:46 PM
The Youth.
20
09-08-2006 07:58 AM
