Turbo Heat Shield Repair ??
Old 11-05-2018, 08:24 PM
qed296
qed296's Avatar
Default Turbo Heat Shield Repair ??
Evening all,
My turbo heat shield isn't in to bad a condition but does have a flap of material that needs fixing.
Any ideas on how to fix it and spruce it up to make it look clean and tidy.
pictures as always of your work appreciated.
Old 11-05-2018, 09:33 PM
costina
Live long and prosper!!
costina's Avatar
Fibre glass resin then give it all a good sanding.
paint with a high heat temp satin black spray.
Old 11-05-2018, 09:51 PM
qed296
qed296's Avatar
Oh, as simple as that.....
I was just concerned about temp and the effect on the repair.
Old 12-05-2018, 07:06 AM
cossynut2
cossynut2's Avatar
Have you tried the various Cosworth breakers for a good used one?
Old 12-05-2018, 07:10 AM
qed296
qed296's Avatar
Not really looking to get another, this is really good compared to some.
The mounting holes are all ok, not opened up or fraying it's just this small area and a little discoloured.
It's worth fixing.
Old 12-05-2018, 10:15 AM
cossynut2
cossynut2's Avatar
It's worth fixing.
Fair enough, have a go at doing it yourself then, seems like its not to hard to repair.
Old 12-05-2018, 10:58 AM
Caddyshack
Caddyshack's Avatar
If you do it with fibre glass as above have said and if worried about the heat still just let me know and I will post you enough stick on heat shield to line the inside with, I have a lot leftover.
Old 12-05-2018, 11:41 AM
qed296
qed296's Avatar
Thanks caddy, I'll take you up on that����
Matt Baxter
26-03-2012 06:12 PM
FestaRST
29-09-2008 07:26 PM
Cola
11
02-08-2006 09:26 AM
scooby8272
06-12-2004 10:21 PM
arch
Ford Escort RS Cosworth
14
06-10-2004 11:02 AM
Quick Reply: Turbo Heat Shield Repair ??
