Heat Shield... erm.. heat proofing!
Howdy Ho
Got a new heatshield (ta Max) to replace the pants bit of heatshield that lives there now. Was advised to cover the back with something heat proof to stop it fading again. I’ve asked about (see Mike, see) and been told that 1: The foam is pants but cheap and 2: The sticky stuff is great but dollars.
Has anyone got any experience of this, who sells what, what works etc? I might even go so far as doing it myself
Or alternatively, just heat-wrap the down pipe.... Also cheap as chips - £15-20 tops.
i would far rather stick some sticky stuff on the underside of the heatshield that is currently on the floor in the front room
Mike:
1: Is it easy to do?
2: How much and where from?
3: I'm guessing that'd take all the heat out so the shield itself won't fade?
That is all (for now )
Caraholic
Originally Posted by Cola
Mike:
1: Is it easy to do? Easy, as in a monkey could do it; difficult, as in pain in the arse to get to
2: How much and where from? Check my website out under heat management . I can also do the sticky stuff, but you need to tell me the area you want to do.
3: I'm guessing that'd take all the heat out so the shield itself won't fade? Which bit are you trying to stop fading?
That is all (for now ) What do you mean for now, you still haven't spent a penny
Mike:
Okay, will have a look on the site. As for the sticky stuff though, how much will a bit be to whack on the back of the heatsheild? A couple of square foot'd do it I guess. Trying to stop the the bit of the heatshield you see going brown.
Mike, don't you know the deal? I ask you all the questions and then go off and buy somewhere else
Caraholic
Mike:
The cheapest heat resistant tape is £20 + del for a 15' reel 1 3/8" wide, which might not be enough to cut into strips to do your heat shield. The next size up is 30' long and would definitely do it, but is £38 + del...
Mike, don't you know the deal? I ask you all the questions and then go off and buy somewhere else Don't I know it
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
07-10-2015 12:56 PM
cossie09
10-09-2015 06:56 PM
