Fuel pump feed??
Fuel pump feed??
A mate of mine has asked me to get his 4x4 Saph running so he can sell it.
It’s been parked up for a while so I don’t know what’s been done or who has been messing around with it.
Its not getting power to fuel pump, what I need to know how the power feed works as it did have an alarm fitted so trying to work out if that is the fault or the engine loom is?
It’s been a while for me since working on the wiring side of things so just need a refresh of someone as I thought the engine loom send’s the signal to the pump so I should be able to test the fuel pump signal feed from the loom?
So I tested the thick red/black wire at the relay near the ecu and it’s dead.
Will that be the feed to the fuel direct from that relay?
Fil
04-05-2014 11:30 PM
FRS-0197
27-05-2009 08:35 PM
DaveEscos
10-10-2005 10:29 AM
DaveEscos
12-02-2005 08:49 AM
