Hydraulic clutch
Hydraulic clutch
Hello
Can help this is driving me mad
Has anyone got any measurements for marking out on the bolkhead the place where to cut the hole for the clutch master cylinder the kit I bought was from reyland and the information they sent me are somewhat vague ????????
Thanks for any help
Thanks for any help
drill the pedal first,then lift the clutch pedal so its level with the other two.
use a small spirit level hold it on the side of the pedal through the centre of the hole youve just drilled and mark the bulkhead,then measure half the thickness of the pedal (cant remember the size now)from the mark on the bulkhead that will give you centre of the pedal.
drill that hole for the rod to go through then you can mark and drill for the retaining bolts.
hope it makes sense 😆
My clutch pedal lines up nicely.
Master cylinder also looks neat and tidy.
