fuel pump rewire
Old 03-07-2016, 01:31 PM
MARKYMARKONE
MARKYMARKONE's Avatar
Default fuel pump rewire
Hi
Ive got a fuel pump rewire kit for my 2wd cosworth.
Now this might be a silly question but do you run the wire under the carpet to the pump or under the vehicle?
Mark
Old 03-07-2016, 02:34 PM
Loomer
Loomer's Avatar
along the sill trims usually.
Old 03-07-2016, 02:44 PM
MARKYMARKONE
Ok cheers
Old 03-07-2016, 03:47 PM
pauloopnorth
pauloopnorth's Avatar
I did mine last week , put the fuse in the boot behind the jack cover , then ran the wire through the passenger side boot then under the rear seat and along the passenger sill into the passengers footwell where there is a grommet that comes out pretty close to the battery
Old 03-07-2016, 04:13 PM
costina
Live long and prosper!!
costina's Avatar
Fuse should be near the battery.
Old 03-07-2016, 05:12 PM
Mad_Mat
New Owner
Mad_Mat's Avatar
Exactly. If the cable between the fuse and battery should short then you would be risking fire.
Old 03-07-2016, 05:13 PM
pauloopnorth
On the re wire loom I bought it was located in the boot along with the relay , then two wires ran from that along the original routing through the boot floor to the pump
Old 03-07-2016, 05:53 PM
Loomer
Loomer's Avatar
So the only part of your loom that was fused, was the part from the relay to the pump, what about the 8 feet of cable running through the car to the battery
Old 03-07-2016, 06:01 PM
costina
costina's Avatar
If that shorted out it would be a big mess.
Put an aditional fuse by the battery to be SAFE......
Old 03-07-2016, 07:01 PM
Adam-M
Adam-M's Avatar
Or have you just wired it back to front by accident?
Old 03-07-2016, 07:04 PM
Caddyshack
Caddyshack's Avatar
Just stick a fuse on battery end and you are done
Old 03-07-2016, 07:19 PM
costina
costina's Avatar
Old 03-07-2016, 07:21 PM
pauloopnorth
yes thinking about it that's going to be a good idea
Old 03-07-2016, 07:23 PM
pauloopnorth
No mate I am no electrical genius , but I did not do it back to front, that's just how it came
Old 04-07-2016, 08:16 AM
Adam-M
Adam-M's Avatar
Who supplied the kit then? I'd stick to buying MSD's (auto dynamix) stuff from now on then.
Old 05-07-2016, 09:24 AM
rdvil
rdvil's Avatar
You generally don't need to rewire it completely - only the bit from the connector in the boot to the pump is rotten.
Old 05-07-2016, 09:29 AM
Adam-M
Adam-M's Avatar
Think it's more to help with voltage losses than to replace corroded wiring which is why people buy the new loom to go straight to the battery and has its own relay and fuse.
Old 05-07-2016, 11:49 AM
martysmartie
martysmartie's Avatar
Correct, although the old wiring does cause this, due to resistance.
In addition, the voltage drops generally via the fuse box (which is overloaded anyway).
So wiring directly from the battery eliminates this, as well as alleviating the load on the above.
Martin
ByronG
17-05-2016 01:42 PM
McCloud 85
11
05-05-2016 10:47 PM
Jules44
24-04-2016 10:09 PM
Avinitlarge
12-04-2016 07:10 PM
Quick Reply: fuel pump rewire
