powerflex Beam Bushes
Old 15-06-2016, 04:04 PM
chrisa3
chrisa3's Avatar
Default powerflex Beam Bushes
Just bought some powerflex beam bushes for my 4x4. i was supirsed when i trial fitted them that the metal sleeve they come with seems a lot smaller that the standard one, ie it moves around quite a bit in the chassis leg holes, where the standard ones seem a snugger fit. also the sleeve is the same depth as the bush see photo.
is this normal? seems the way the standard mount protrudes into the leg would stop the beam moving and add support to the bolt, where with the powerflex, it does neither.
am i missing something??
Old 15-06-2016, 07:22 PM
Marc sierra
Marc sierra's Avatar
The bush will compress so the sleeve will still be long enough. And the sleeve will be clamped by the bolt so it won't move around.
Old 15-06-2016, 08:31 PM
chrisa3
chrisa3's Avatar
ok thanks
Matty_C
04-08-2016 07:46 PM
dreamin
10-07-2016 09:02 AM
M K
19-06-2016 09:45 PM
TrevCos
26-05-2016 04:40 PM
TrevCos
23-05-2016 11:13 AM
Quick Reply: powerflex Beam Bushes
