A few spare wires
Old 02-06-2016, 05:55 PM
4x4kiwi
4x4kiwi's Avatar
Default A few spare wires
Just curious if anyone knows what these wires are for (not apparently used) on my 1990 4x4 Cos. The single blue one with a spade connector on it is in a loom in behind the battery but is not the one for the standard alarm horn (which has the same type of connector). The second 2 pin plug is in the engine loom that is curled up in the slot in front of the scuttle panel. I thought at first it may have been lamda sensor - and one of the wires was the right colour, but believe this is a 3 pin triangle shaped connector. Thanks David
Old 02-06-2016, 07:04 PM
Dezzer
4x4 resto
Dezzer's Avatar
Apparently the two pin is for aircon on later models mate , not sure about the single spade one
Old 03-06-2016, 02:46 AM
rdvil
rdvil's Avatar
Something removed from the car maybe? Gasoline vapor canister purge perhaps.
I think all A/C connectors by the bulkhead are behind the scuttle panel. If the alarm has been removed, maybe the single wire could be for the hood switch.
jim_robson
29
06-05-2016 01:49 PM
col93saphcos
15-04-2016 09:09 AM
Farmer Giles
31-03-2016 09:14 PM
johnandhissaffy
13
31-03-2016 06:21 PM
bodace5
25-03-2016 07:35 PM
Quick Reply: A few spare wires
