top and bottom End knock on rebuilt yb
Old 05-01-2014, 12:35 PM
cosmik
cosmik's Avatar
Default top and bottom End knock on rebuilt yb
Yesterday I finally finished rebuilding my cossie started it up and it ran prefect went with the first turn off the key but I have come back to it today n it had devolped a knocking from the top and bottom End. I have replaced all the big end shells the little end shells all the cam shells is had new pistons and rings the oil pressure is reading 2.4 bar cold then just over 1 bar when warm I haven't replaced the oil pump but it was working fine before I spotted the car and the old shells hardly had any wear on them. If anybody has any ideas is love to know to save me having to rip the engine out again and starting from scratch. Cheers
Old 05-01-2014, 02:55 PM
dug112y
passionford pro
dug112y's Avatar
did you measure everything during the build or just buy n fit? did you strip pump and check it?
Old 05-01-2014, 03:08 PM
tones
tones's Avatar
Sent yo a pm
Old 05-01-2014, 03:37 PM
cosmik
cosmik's Avatar
Just bought n fit everything. Everything fitted snug into the new shells the only thing thay I did notice was there was some side to side pay in the con Rods not sure if that is normal or not and no I didn't strip the oil pump as I thought it was working fine before but reading up on the pressure it should be mine seems a bit down on what bar it should be
Old 05-01-2014, 03:49 PM
ickey818
ickey818's Avatar
Have you checked all the pulley bolts are tight? I had one work loose on the auxilary shaft that drives the dizzy and that made a knocking noise.
Worth checking all the pulley bolts are tight before you start stripping the engine again.
Old 05-01-2014, 03:52 PM
DixieTheKid
Pick-up P100 Power!
DixieTheKid's Avatar
You replaced the cam shells?
Old 05-01-2014, 04:25 PM
Paul_RS
Paul_RS's Avatar
What are cam shells?
Old 05-01-2014, 04:32 PM
dug112y
passionford pro
dug112y's Avatar
How do you know if the clearances are right??
Did you gap the new rings? Oil pressure seems low. What's a cam shell?
DixieTheKid
Pick-up P100 Power!
You replaced the big end and small ends but you didnt replace the mains?
Did you measure the journals and check them for wear? Plasigauge them and check the end float?
Why did you replace the pistons? Are they oversized? Did you have the block honed?
Where did you get the cams shell from? I forgot about those. Ill speak to MAtt Lewis in the morning.
Old 05-01-2014, 04:33 PM
dug112y
passionford pro
dug112y's Avatar
Drop the oil out it and see if it looks silvery or if there is debris in it.
Old 05-01-2014, 04:34 PM
Minirotty
Lucifer II - 666
Minirotty's Avatar
Is this Mo?
Old 05-01-2014, 04:57 PM
cosmik
cosmik's Avatar
I meant to put mains not cams dont no why I put that... I changed the pistons because I was going to get the valve cut outs put into the originals but I got offered a deal for new pistons with the cut outs already in and a set of grey injectors. yes all the pulleys are tight I have checked them all.
Old 05-01-2014, 05:04 PM
botters
competant bodger
botters's Avatar
lots of cars have cam shells these days , cossies dont like!
Old 05-01-2014, 05:05 PM
DixieTheKid
Pick-up P100 Power!
What make are the pistons? Did std pistons come out?
Did you measure the journals, plastigauge and check the end float?
Old 05-01-2014, 05:23 PM
cosmik
cosmik's Avatar
They are standard mahle pistons that came out and the new ones are mahle pistons aswell also standard. The clyinders gave been honed n no I never checked them... is it going to be the case of engine out again or can I get away with removing the sump to check them?
Old 05-01-2014, 05:27 PM
DixieTheKid
Pick-up P100 Power!
No offence here bud, but pull the engine out and take it to an engine builder.
Have it done once, and have it done properly.
Old 05-01-2014, 06:50 PM
james kiely
james kiely's Avatar
cosmik have you used mineral oil to run it in ?
Old 05-01-2014, 07:20 PM
graham c
graham c's Avatar
did you lay the engine on the oil spay pipe as it only just clears the crank and many people have bent this
Old 05-01-2014, 07:57 PM
rstoughy
rstoughy's Avatar
Have you checked it's timed it up properly?
It's very easy to time it up a tooth out.
On a Cosworth time the bottom pulley to the lug NOT the V.
Stick a ratchet / socket on, turn it over by hand to the marks and check.
I have seen ones a tooth out clipping the valves / pistons when running.
Got to be worth a check before going any further.
Hope it's an easy fix.
Old 05-01-2014, 08:24 PM
LHD220Turbo
LHD220Turbo's Avatar
I suspect the tolerances are too big, hence the knocking.
Old 05-01-2014, 08:34 PM
costina
Live long and prosper!!
costina's Avatar
and the low oil pressure at idle
Old 05-01-2014, 08:35 PM
costina
costina's Avatar
This is very true and it will touch the inlet valves if timed up like a pinto which was a common mistake.
Old 05-01-2014, 09:40 PM
L1AM_RS
L1AM_RS's Avatar
Hope you get it sorted mate!
As said, you NEED to remove the engine and unfortunately rip it to bits. I'm currently 80% rebuilding my engine. If you need any advice ask.
Before installing the crank finally you should of checked your clearances with plastigauge to ensure you are within tolerance else you will run into issues. You also need to consider ring gaps, end float etc etc! There's alot to get right!
I'd suggest you buy a workshop manual also as it gives you all the relevant torque settings / clearance's etc.
I did weeks of research before i tackled mine.
Good luck!
Old 06-01-2014, 07:27 AM
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Agreed. Do you do your own dentistry as well same risk of the unskilled making a hash of it as building an engine with out knowledge of the job in hand.
KW-rscos
11
31-08-2015 01:51 PM
29-08-2015 08:16 PM
IAN RS2k
18-08-2015 07:51 PM
Bailes1992
16-08-2015 07:14 PM
john_3.0s
15-08-2015 07:44 AM
Quick Reply: top and bottom End knock on rebuilt yb
