AP help
Old 30-09-2013 | 12:50 PM
Tinshaw's Avatar
Tinshaw
Default AP help
Hi fellas
I'm thinking of buying some AP 4 pots 330mm & was wondering if these would fit behind 17 inch super turismo wheels???? Or is there away of working it out?? Any help would b grate.
Cheers Lee
Old 30-09-2013 | 05:45 PM
charlie luciano's Avatar
charlie luciano
What varient is the car 2wd or 4x4? what offset are the super t's? 4x4's are a bit of a pain in the arse to fit big brakes to up front, you'll need an 8jx17 rim with an et37 to get the brakes under the rim
Luciano
Old 30-09-2013 | 09:30 PM
Paul_RS's Avatar
Paul_RS
Depends on the caliper you use. I had an AP supplied kit on mine (cp 5200 calipers) and it didn't fit behind super ts without spacing the wheels at least 5mm.
Old 30-09-2013 | 09:34 PM
JamesH's Avatar
JamesH
If 2wd then yes
Old 30-09-2013 | 10:11 PM
Tinshaw's Avatar
Tinshaw
Sorry I ment to put 4x4 saph!!
Old 01-10-2013 | 12:06 AM
Paul_RS's Avatar
Paul_RS
See my reply for 4x4 issues.
Old 01-10-2013 | 08:10 AM
Jay,'s Avatar
Jay,
Sponsor
thats how mine are fitted
Old 01-10-2013 | 12:47 PM
Tinshaw's Avatar
Tinshaw
So if it is a a cp5200 kit will it just need 5mm spacers??
Sorry to sound a bit dim but don't really fancy paying out 4 them if I've got change wheels 2!!!!!
Is there any way of checking the wheel without fitting it all 1st??
Cheers Lee
Old 01-10-2013 | 09:10 PM
matthewpickup's Avatar
matthewpickup
I'm in the same boat as you mate , although I have different wheels
I have trial fitted mine and the callipers stick a fair bit out but with 5mm spacer it would fit just need longer studs
you could try yours on and use washers as a spacer to see if you could get away with it ?
