had a look at the loom today , who dose new ones?
as above i had a look at the sierra 4x4 engine loom today and cant see where it gets the power from , tbh i really dont know a great deal about this so any help would be good , so i take it there would be a feed from the fuse box then into the loom or plug on the loom ? do i need the loom for inside ie bulkhead to plug into the engine one? any one with pics of that end the loom would help me try and work it out .
thinking about a new loom as it maybe easyer to fit ?
thanks for any help or info on this
thanks
Pick-up P100 Power!
Are you using the p100 loom or a cossie loom? I used a cos 4x4 loom but a 3door loom would be easier. If you using the p100 loom I'll show you a pic of the plug and you can just power it up by running the wires from the ignition behind the dash to the engine loom plug.
yea i am using the 4x4 cosworth engine loom and the p100 car side so as you say just get the power wire and power it up from there
Pick-up P100 Power!
No probs. I'll add some pics to this thread for you tomorrow mate. If you don't have a loom I have three but one is in the car one spare and the other is with my dad who is making me a new one. Once I have that back your welcome to it for 50 as that's what I paid for it.
Pick-up P100 Power!
As promised bud,
Pictured is a 2wd loom (right) and the engine loom part of the 4x4 loom (3 peices)
Here is the plug to power the loom on the harness
And here is the plug on the car loom
I do have a ghia loom down in the shed, ill see if it has that plug on it. If it goes then ill cut out the bit you need a post it to you. Should make life a bit easier.
Hope this helps.
Hope this helps.
As promised bud,
Hope this helps.
Hope this helps.
have to say well done that is a big help for me will check my loom tomorrow i think it has that plug on it , and will check the pick up too if not i will give you a shout and buy that parts needed from you mate , thanks again
muz
30-09-2015 08:29 AM
rsguy
44
29-09-2015 03:29 PM
