polly diff mount question
01-07-2012, 08:53 PM
i fitted mine today and the mount and the bump stop are touching,anyone had this issue?
is it just a case of taking off the bump stop?do i need it ?
01-07-2012, 09:43 PM
No need for the bump stop with that mount mate just take it off
01-07-2012, 10:22 PM
That sorts that out as mines the same
02-07-2012, 07:30 AM
Dout it will do any harm, infact it woud stop the water getting in .
02-07-2012, 04:10 PM
Quote:
Originally Posted by
RONNIE AMIS
cheers ronnie will do.
Harris.
harris the only problem i could see is that it would cause a vibration through the shell.
ill be taking it off.
cheers.
02-07-2012, 04:27 PM
Fitted mine yesterday also, but mines a saph and doesnt have the block on the spare wheel bowl.........
Only problem I had was that the 2 bolts into the diff casing were 5mm to long
02-07-2012, 04:33 PM
from what i understand mike everyones had to do the same,i think i removed about 4 threads from the bolts
03-07-2012, 07:20 PM
I kept mine on but just cut a notch out of the top of the bump stop.
04-07-2012, 05:17 AM
No bump stop here and yes the bolts are to long
Massive difference on track with the poly diff mount
04-07-2012, 05:49 AM
MARCOSWORTH
I'm yet to drive mine, what am I likely to notice?
04-07-2012, 07:26 AM
Mine is much more stable under braking and high speed corners
04-07-2012, 08:23 AM
is this a msd kit?if so why dont they supply the right length bolts??
04-07-2012, 09:14 AM
lukeytheduke
Same here, everyone I know has has to chop the bolts.
Good bit of kit but the fittment could be made easier..
04-07-2012, 09:43 AM
I'm sure I read that there is a variation with the depth of the threads on the diff plate from car to car,
So I'd say it's better they are 5mm to long than 5mm too short.
I sent all off the fixings for chrome and zinc plating before fitting mine
04-07-2012, 10:06 AM
PassionFords Creator
saphcosmike
Exactly correct mate, for some reason the threaded bolt holes are not all exactly the same depth... typical 80s Ford sadly.
04-07-2012, 10:18 AM
Stu @ M Developments
Surely it would have been easier and quicker to make all wholes the same in terms of production line and even costs- like they done with the rest of the car??
04-07-2012, 10:16 PM
It's easier to grind something off then something on
04-07-2012, 11:51 PM
How much variation can occur On something with a +/- .25 tolerance.
Does anyone know of someone that hasn't had to chop there bolts down?
05-07-2012, 06:03 AM
rs enthusiast
cozzy jeff
yep ditto
yatta
21-05-2016 10:31 PM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
155lee
27-10-2015 04:55 AM
IainRS1700T
25-09-2015 06:44 AM
