pf09 in l6 ecu
Old 07-05-2012, 06:46 PM
crystal cossie
crystal cossie's Avatar
Default pf09 in l6 ecu
Just tested my 2wd tps and it's knackered, I know the pf09 will fit but will it work correctly, also who still sells these new?
Old 07-05-2012, 06:59 PM
BRAMMER
BRAMMER's Avatar
I thought the 09 was for L8 etc and L6 ran 01
I'd try GGR, Matt Lewis, Woodford garage, Burton as someone must have one
Old 07-05-2012, 07:01 PM
Turbosystems
Super Moderator
Turbosystems's Avatar
pfo9 is not suitable for a l6
try mat lewis etc
Old 07-05-2012, 07:06 PM
crystal cossie
The one on the car now is an 01, but these are not avaiable new anymore. The reason I ask why it will work properly is that some threads on here say it will and some say it won't. If it works ok I'd rather buy a new 09 than take a chance on a second hand 01.
Old 07-05-2012, 07:13 PM
Turbosystems
Super Moderator
a pfo9 will not work on an l6
its works the opposite way round to a pfo1
a pfo9 is 0-5v
a pfo1 is 5v-0
It is rumoured that I may know a little bit about weber ecu's and cosworths
they don't make the pf09 anymore
Old 07-05-2012, 07:19 PM
crystal cossie
I suppose I will have to take a chance on a secound hand pf01, probably from ebay
Old 07-05-2012, 07:24 PM
RSricRS
Long live the ford RS'S
RSricRS's Avatar
Pf09 does work with l6 management, pf01 doesn't.
Old 07-05-2012, 07:26 PM
RSricRS
RSricRS's Avatar
Pf01 are used on earlier 3door cossies, which didn't run l6.
Old 07-05-2012, 07:30 PM
RSricRS
RSricRS's Avatar
Forgot to mention that burton power sell pf09 tps's
Old 07-05-2012, 07:34 PM
Turbosystems
Super Moderator
correct but the OP's question was about an l6
Old 07-05-2012, 07:37 PM
Turbosystems
Super Moderator
there was thread a few weeks ago
something about being Ł250 from Burtons but none available
he needs a pfo1 or an l8 to go with a pf09 and a little loom mod
BRAMMER
BRAMMER's Avatar
a pfo9 is 0-5v
a pfo1 is 5v-0
I know where i'd be taking my advice from
No it doesn't
But used the same TPS on both L1 & L6
No they don't
Old 07-05-2012, 07:40 PM
crystal cossie
Getting confused now, mine is a pf01 with l6 ecu. Just to clarify, I cannot use the pf09 and will have to find a good second hand pf01
Old 07-05-2012, 07:42 PM
Turbosystems
Super Moderator
As I posted earlier try matt lewis last time i spoke to him he had located a supplier and was negotiating a purchase
he wasn't sure if it would come off
ring him tomorrow and ask
Have you checked his web site shop
Old 07-05-2012, 07:43 PM
Turbosystems
Super Moderator
a pfo9 is 0-5v
a pfo1 is 5v-0
read this this guy seems to be a bit clued up
and he is fookin good lookin too
Old 07-05-2012, 07:48 PM
crystal cossie
I will phone matt lewis tomorrow hopefully he sells them otherwise it will be a second hand job
Old 07-05-2012, 07:54 PM
Turbosystems
Super Moderator
was your fist hand job that good
Old 07-05-2012, 07:58 PM
RSricRS
RSricRS's Avatar
Well I have l6 running a pf09 so how does it not work?
Old 07-05-2012, 08:02 PM
crystal cossie
If the 09 does work then great, I just want to know either way before I buy one.
Old 07-05-2012, 08:03 PM
Turbosystems
Super Moderator
oh dear
do you have idle speed control issues
thats the first most obvious issue
the other issues are far worse
you sure it is a pfo9 and l6 before we get to in deep in technical discussion
Old 07-05-2012, 08:04 PM
Roscopeco
P8 Managed S1 with ALS
Roscopeco's Avatar
No disrespect to Ric but i reckon Mr Turbosystems knows whats what tbh
Rob Virgo
Rob Virgo's Avatar
I'd say you have the wires swapped which WORKS but not ideally
Old 07-05-2012, 08:08 PM
RSricRS
RSricRS's Avatar
Lads totally forgot am running l8!!!!!! It's a long story lol
Old 07-05-2012, 08:20 PM
Paul500+
Paul500+'s Avatar
ive got a good pf01 if you need one
swopped mine to l8 pf09
Old 07-05-2012, 08:28 PM
Turbosystems
Super Moderator
a pfol starts open circuit at throttle closed initial trottle open is then 5v progressing down to 0 v at full throttle this is what the l1 an l6 need to see
apfo9 starts at 0.2 v and progresses upto 5v at full throttle
the tps start position is critical on the l8 the l8 needs to see 3 to 5 degrees of throttle angle at throttle closed
the l1 and l6 needs to see open circuit at throttle closed
Old 07-05-2012, 08:29 PM
crystal cossie
I'd rather a new one, but how much are you looking for?
Old 07-05-2012, 08:32 PM
Paul500+
Paul500+'s Avatar
Ł25 posted thats cheap, one on ebay for Ł60 up to you m8
Old 07-05-2012, 08:33 PM
Paul500+
Paul500+'s Avatar
or if you got a pf09 will swop yer
Old 07-05-2012, 08:43 PM
crystal cossie
I'll take it for Ł30 if you can post next day delivery. How are sales done on here? Do you need to create a sale thread? PM me payment details etc.
Old 07-05-2012, 08:47 PM
Paul500+
Paul500+'s Avatar
pm sent
Old 07-05-2012, 08:58 PM
Mungus
Mungus's Avatar
Very useful thread - thanks guys... think you may have saved my engine !!
I only read this out of interest, but my 4x4 has a red TPS which looks to be the 01..... and it needs the 09???
Will put a probe on pin 17 I think to check if the wires have been switched.
Wanted.... working PF09 lol!!
Huw
Old 07-05-2012, 09:15 PM
saph cos rob
swindon rsoc
saph cos rob's Avatar
double check before buying mate as the early PF09's were red
Old 07-05-2012, 09:46 PM
martysmartie
martysmartie's Avatar
PF09 does NOT work with L1/L6 it may well work to a degree but it won't run properly.
Martin
Old 07-05-2012, 09:47 PM
martysmartie
Huw
There were avaliable in both colours, it's marked on the TPS, if in any doubt just check the output, although if it were wrong you would notice it as it would run bad.
Martin
Old 07-05-2012, 10:14 PM
Turbosystems
Super Moderator
the black pf09 is an improvement over the earlier red pfo9 and was standard oe fitment on all BT p8 escort cosworth and it was important that they have them on the p8 as it is speed pressure throttle angle as opposed to speed density for the l1 and l6
Old 12-05-2012, 08:03 PM
Mungus
Mungus's Avatar
Fantastic... mine is a red PF09
interested me to test it today though....results wernt good though so I thought id confirm with you guys.
I have put a probe on the pin 1 (ground) and pin 17 and with throttle open and closed, the results were both 0V
So... ive either got a chuffed TPS.... or im testing it incorrectly.
TO test, I have taken the multiplug from the ECU and tested probed the pins 1 and 17 according to the techical diagram I have.
Would this be the correct way??
Looks like a bit of a pain to change too... perhaps best to move the throttle body completely??
Huw
Old 12-05-2012, 08:22 PM
Turbosystems
Super Moderator
Huw
daft question really but did you have the ignition switched on
Old 12-05-2012, 08:34 PM
Mungus
Mungus's Avatar
lol..... yup, ignition on
Probe was monitoring constantly from no throttle to full.
Was this the correct method to check?
Huw
Old 12-05-2012, 08:42 PM
Turbosystems
Super Moderator
stick the probes in pin 11 and 30 and note the result meter set to 20volts DC
then pin 11 and 17 and check voltage readings at min throttle ,quarter throttle half throttle and full throttle
ignition on
Old 12-05-2012, 08:46 PM
Mungus
Mungus's Avatar
ignition on
Will check in the morning... thanks for that. Will report back!!
Cheers!
Huw
Quick Reply: pf09 in l6 ecu
