cossie running problems
heffo
my 3 door cossie drives no problem on open road but if car is in slow traffic or left to idle for a while and gets warm enough for fans to cut in car will splutter and run bad and wont pull right .car is not boiling or anything .ive changed air temp sensor water temp sensor and crank sensor still no joy .any help would be apreciated its wrecking my head
I admit this is a guess on my behalf, but have you checked the voltage readings from when it runs normally to when it runs badly ie with fans on? Could be it's drawing too much power and struggling to feed the other systems ie ECU.
cheeRS
cheeRS
Received 1,042 Likes
My saff used to di a similar thing.I changed the water temp sensor.
When i first started my car up it would run mint but as soon as it got up to temp it used to misfire like fook.
heffo
cosworth running bad
alright heres the problem when i start cossie it runs fine and will all day unless you run into traffic or let tick over for a while say until temp reaches fan cut in temp then it starts to splutter stall and backfire and eventually cut out.ive changed water temp sensor/air temp sensor/coil/dist cap/rotor/phase sensor /crank sensor/leads/ignition amp/im at my wits end really pissing me off its going on a year now.any help would be appreciated
Karl 3dr
102
14-10-2016 08:17 PM
kosienutter
31
22-08-2015 09:55 AM
Stu @ M Developments
41
21-08-2015 06:47 AM
Zoggon
10-08-2015 10:39 AM
