550-600bhp on a YB, whats needed?
#41
Whilst we are on the subject of 550bhp plus. I wondered what benefit I would see of long stroke by over normal, I understand you get better rod angles and I assume the extra 200 odd cc will make the turbo spool faster due to more exhaust gas?
I also assume that 200cc extra simply adds power.
I wonder if my efr turbo would struggle though as it tops out at 530 bhp. I know I can get 530 without long stroke but once I get to 500 bhp and more I am more interested in torque, fast spool and road drivability.
I doubt an ally block would be worth the £3000 plus extra on this spec although I like the reduced weight and 2.5 possibility. Should be quick in my pug 205 which is close to 1100 kg.
#43
cossie fan (unluckerly)
#44
Mark
#45
I thought about the idea of a more modern crank and as mark put it the yb one is 20 odd years old now. But to me I had to draw the line some wear as it is an expensive crank and to be fair the power I want will be shockingly quick on the road so it will be enough for me at it is spec'ed. plus mark said the standard crank will be ok at that power level
I had 500 bhp in an AMG merc which was supercharged and it used to totally put the power down through 2wd and an lsd but that was nigh on 2 tonnes so the lower weight should make it lively. Miy 205 certainly felt fast on low boost at 430 bhp but I am keen to try the high boost map one my box is finished as 420 did not feel as fast now the lag of the t34 had gone.
#46
It should have instant responce everywhere I really like the long stroke motors I do. I have sold a turbo kit to a 2.340cc engine and recommend a 7670 on such a large engine to make sure it makes it 500hp and hold on to it where if it had a 7064 I would expect it not to hold 500hp past 6500rpm.
Mark
Mark
#47
Mark
#48
What power will you be at then?
#49
Cool, my spec for the driveline is that apart from the 6 degree but that is coming soon.
#50
I guess if we go to that turbo on a long stroke we will be nearer 600bhp once the head, cams and Pistons are done?
#51
Whats the aprox cost of doing a stroker engine
smiley (12-04-2015)
#55
It's funny, I was at the traffic lights today in my 1.9 gti with 160bhp engine and a brand new c class merc made it clear by edging forward that he was up for a drag, I pulled away and mullered him, now that is probably a 6-7 second car to 60.... He pulled up at the next lights and tried again,.....I monstered him. Now we are looking at prob 400 bhp and similar torque on top of that in a 4wd car with 2 limited slip / atb diffs and an active centre diff in the same weight body shell with just the transmission, cage and body kit on top....I wonder how much quicker with launch and anti lag that would have been on 580bhp?
#57
#59
Over 5 was a guess it soon all adds up! I'm keeping the standard crank as told it's good for 700. Not as good as a more modern crank but there expensive
#61
Got to be a hard question to answer really as different tuners have different ideas. Only a couple of builders who build these engines to a high standard it is expencive if you want a good engine that will do what your told it will. I was told a stroker kit is the way to go but the crank is over two grand plus I'd need oil spray jets so took the other option as a standard crank will do me for a 650 ish build
#62
i was discussing spec with ahmed it came up that at 500 we wouldnt need to uprate bottom end so me saying 500 std crank was probably wrong of me mate couldve ment other components at 600 we do more of a costing convo at the time
#63
#64
#65
I think you can be like Rod Tarry and go closer to 1000 bhp if you buy an after market crank on std stroke but you will be spending £30k plus to get to that spec from scratch I would think.
The strokers will depend on the turbo and head work, I would think 700-800 bhp or more is fine if your pockets are deep enough, but at this level the fuel system, brakes, suspension and gearbox / diffs are going to need lots of money to keep up.
Even at 500 bhp in 4wd you need some pricey diffs and gearboxes to be reliable.
#67
Happily retired
The fuel system is the forgotten part. If you use fancy fuels like FTW Purple at very high boost it can double your fuel needs. We are going for a Veyron P1 pump but above 3.5 bar we need 2 of them so that's £1500 on pumps it can get really mega expensive over 900bhp.
#68
I have some questions concerning the CR and stroke for a setup aiming at 550bhp. Hope you can help.
So if i have an engine with a CR of 8:1 and std. stroke and bore with that power curve:
Can anyone give an educated guess how the power curve would look like if the engine had a CR of 9:1, std bore and a stroke between 84mm-88mm? Does it even make sense to go for stroke without changing the bore?
How much stroke can a std. block accept before machining is needed?
Where can i get pistons an rods for a CR of 9:1 that can take 29 psi of boost of an efr 7163 all day and night?
Thank you very much.
PS: that dyno is of an yb engine. If i violated someones rights, because i used that dyno, plz tell me i´ll change as desired.
JoeyBoyden
04-01-2024 02:36 PM
jessie_rs
11
03-06-2019 04:57 PM
rog
04-09-2015 12:10 PM
borboyous
22-08-2015 11:17 AM
