2wd T5 gearbox rebuild
I,m looking at getting this done over the coming months and most likely the diff too , how much is a working but tired gearbox going to roughly cost to rebuild/recondition ? Mine is in working order (just about) and being as the engine is coming out soon , now is the best time . Does anywhere stock recon units for exchange too?
Many thanks
Mike
Many thanks
Mike
Many thanks
Mike
Many thanks
Mike
Hiya Mike i posted same question last week on here BARA is the best place for box an they do diff's too
Hi Mike,
My gearbox was Ł580, but everything that could be worn was worn, needing synchro on all 5 gears, a normal build is about Ł350 from the peeps I use, they also do diffs, although there is a ace place in Kent not far from dartford that does diff rebuilds/mods.
If it's whiney it's on borrowed time, the lever mechanism is likely worn for the slop to be there.
At the base of the lever mechanism there is a ball/socket joint, this wears over time, but there is a 100% perfect cure, that's not expensive either.
TPM961
15-01-2018 10:50 AM
