Oil feed. T4 onto 4x4 head help!
20-03-2011, 05:06 PM
Fae the Dale
I need a oil feed hose for my T4 turbo. Bother is there isn't much room for the 90 bend between the head an turbo. So it has to be quite trim. The standard 4x4 hose fits the connection but is too short. I'd buy one of these ones with the filter included but dont know if the bend will be tight enough to fit etc. Anyone have a solution for me?
thanks
20-03-2011, 06:41 PM
Banjo bolt and fitting ?, can get in all different angles.
20-03-2011, 06:48 PM
SIERRA RS 4X4 COSWORTH
I am switching to the 2wd style on my t4 ,4x4 saph .
20-03-2011, 06:52 PM
the standard 4x4 oil feed hose does fit mate? well it did on my t4 powered 4x4 cossie
20-03-2011, 07:52 PM
just blank the head of and convert it to the same as 2wd's from the other side of the block.
you get a better oil supply from there
20-03-2011, 08:00 PM
Fae the Dale
Where does the 2wd feed come from? Any pics?
20-03-2011, 09:53 PM
Cake lover!
Feeds from where your standard pressure switch is under the inlet.
21-03-2011, 08:49 AM
Quote:
Originally Posted by
BIG WULL
There's an adaptor that screws into your block for oil pressure switch, a 2wd adaptor has a oil feed take off.
21-03-2011, 06:03 PM
Fae the Dale
ah. thats a no-go i'm afraid. Switch is already fouling the filter because the take off for the pressure gauge sits there
28-03-2011, 08:37 PM
Fae the Dale
Does anyone know where i can get the adaptor for my oil feed to runn 2wd feed? Also a blanker for the 4x4 oil feed on head??
28-03-2011, 08:57 PM
the oil feed pipe does fit mate like dicko has said. we have also fitted one
29-03-2011, 07:45 AM
i used these
Fitted like this-with stack oil pressure gauge fitting
Burtons sell the fittings .
hope that helps .
29-03-2011, 08:28 PM
Fae the Dale
Carl/saff
Thanks alot this was as helpfull as it gets!
Pint on mee
30-03-2011, 11:51 PM
Has a large member
Hi mate, i can make you up a custom pipe with earls fittings and inline filter to whatever length and fittings you need if that helps
Heres my set up below..
hopper350
04-09-2015 12:53 AM
CrOwSoN15
14
03-09-2015 12:21 PM
StephTell
02-09-2015 06:31 PM
mint_s2
02-09-2015 08:58 AM
4x4 ,
cosworth ,
fiting ,
ford ,
gauge ,
head ,
oil ,
paaaion ,
pressure ,
saff ,
wull
