Not holding boost
Old 19-03-2011 | 09:32 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Default Not holding boost
My stage one saph was boosting to 18psi. It's now only holding 13psi. I'm guessing the spring in the actuator is knackered - possibly due to fact I had a hose split recently allowing turbo to boost to 30psi. It only did this twice before I realise but could this have weakened the spring?
If it is the spring will I need a new actuator or can u carefully adjust on the rod until I get back to 18psi?
Old 19-03-2011 | 09:46 PM
LHD220Turbo's Avatar
LHD220Turbo
the spring has probably gone weak over time; new actuator needed
Old 19-03-2011 | 10:13 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Cheers, thought that could be the case. Are they easy to change?
Old 19-03-2011 | 10:17 PM
LHD220Turbo
easy, just make sure you preload the new actuator.
start off low and keep shortening the rod until you reach your desired psi, 1 turn on the actuator rod will roughly equate to 1 psi. you will have to take it out for a run each time.
Old 20-03-2011 | 10:17 AM
Jimboxr4x4's Avatar
Jimboxr4x4
Blinding, cheers for the help.
Old 20-03-2011 | 11:56 AM
Jimboxr4x4's Avatar
Jimboxr4x4
Is it a -31 I need for max 20psi boost?
Old 20-03-2011 | 12:25 PM
cosy trav's Avatar
cosy trav
Yes the -31 will be fine for that pressure , dont forget to take a passenger to watch the boost guage .
Old 20-03-2011 | 12:35 PM
LHD220Turbo
incidentally, 18psi is quite high for a stage 1
you still on yellows and a t3?
Old 20-03-2011 | 03:25 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Yes mate - think the t3 should be okay at that level but was wondering if I need greens?
Old 20-03-2011 | 04:47 PM
martysmartie's Avatar
martysmartie
It depends on if it's mapped for it or not, stage 1 is circa 15PSI but it depends entirely on the setup, Gunship for example uses stock components but can run near stage 3 power!
You can't simply just change injectors as the software has to be progremmed for the specific injectors, different pulse widths etc!
Martin
Old 20-03-2011 | 05:07 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Cheers, it's been set-up to hold 18psi so guess it should be okay then.
timsrs
13-11-2018 12:48 PM
01-11-2015 07:53 PM
Mark RS
12-10-2015 07:01 AM
XR4
Ford XR Range
01-10-2015 01:46 PM
Russ Payne
25-09-2015 09:29 PM
