Cosworth ecu l8 connecting with closed loop lounch,anti lag,wasted spark driver??
Hello all,i bought one cosworth L8 ecu with closed loop,anti lag and lounch control system,and Wasted Spark Driver plus the wirring loom for 2 amplifiers but there is one brown plug and i don't know where is the plug in,so does anyone know the connecting for this plug and the connecting for anti lag and lounch control? any help really appreciated
![](http://s2.postimage.org/a8px0io3v/P1019803.jpg)
![](http://s2.postimage.org/dsbwdv3bp/P1019794.jpg)
![](http://s2.postimage.org/hbxvr7igs/P1019796.jpg)
hosting images
Regards Themistoklis
hosting images
what need to do to my engine to work anti lag and lounch control separately,i mean i want one switch for anti lag and one another for lounch so does it feasible that?thanks a lot fo r any advice!!!
also what modification need to work these systems?
Regards
Regards
Send me the chipss Serial number to sales@motorsport-developments.co.uk and ask for the instructions to go with it mate and I will look after it personally.
Best Regards
Themistoklis
the 2 wires go into the ecu plug. i fitted my coil pack today and it was pin 21 & 26 but that was level 6
looks like stus on the case though
Ok, got your email now and have replied, with attached instructions, but just in case my reply gets lost like your first mails, here you go:
Hi,
Thanks for your enquiry and purchasing one of our calibrations. The info we hold on file for that item are as follows:
Basic Calibration Specification for 3772:
Originally Sold: January 2008
ECU Type: L8 ECU
Babyboard Required: Yes
Encryption Key required: Yes.
Pectel or Weber: Weber.
Engine Type: Ford YB 2.0
Engine Compression: Standard
Head Spec: Standard
Camshaft Spec: Standard:
Injectors: Siemens 5lB
Turbocharger: T4
Map Sensor: 3 bar
Intercooler: RS500 type
Additional Features Installed:
Closed Loop active: Yes.
Air Injectors active: No.
Serial Data active: Yes.
Anti Lag active: Yes.
Launch Control active: Yes.
Flat Shift active: No.
ECU Type: L8 ECU
Head Spec: Standard
Turbocharger: T4
Map Sensor: 3 bar
Location: Yarm (Teesside) previously from Fyvie (Aberdeenshire)
cozzy jeff
14-08-2015 05:46 PM
Escortdriver1
31-07-2015 02:36 PM
