Timing marks
SHELL GARAGE VIP
Timing marks
Can somebody please confirm the timing marks for when im changing my timing belt,I think its 2 pointers face each other and woodruff key at 12 o'clock is that correct?and do I need a puller for the crank pulley?
Its a 4x4 saph
Thanks
David
Its a 4x4 saph
Thanks
David
Just don't worry if piccie 5 is out, it's of no significance so long as piccie 6 is correct.
Do you need a puller ?, hopefully not, just have to wait and see.
If you do have trouble with the crank pulley coming off, knock out woodruff key for pulley once off and lap a bit using valve grinding paste between the pulley and crank nose, till it's a snug but not stupidly tight fit, make sure to wipe all traces of paste away before reassembling and putting woodruff key back in slot, smear with coppaslip or similar and it will come off much easier next time.
There is no need at all for locking stuff on the thread of the bolt just std torque is fine, it won't come loose.
MK Motorsport Matt
75
15-11-2015 11:22 PM
StephenC
09-10-2015 09:33 PM
