tremec xr3r gearbox fit yb? difference from T5?
Old 21-01-2011, 07:27 PM
crumpet
crumpet's Avatar
Default tremec xr3r gearbox fit yb? difference from T5?
would a tremec xr3r box like this work with a Yb?
Is it a stronger box and is it geared different at all?
http://cgi.ebay.co.uk/Tremec-Gearbox...item4aa7c7b982
Old 22-01-2011, 05:22 PM
It wouldn't be impossible to get it to work, but would need a one off bell housing, or adaptor, as it secures different to the T5, there are a minimum of 380 versions of the T5, it's even used on the SANG YONG MUSSO for example!!
The ratio's would be very widely spaced in comparison to a cossie T5, which you can get alternate gear kits for anyway.
As a financial proposition it's a no go, rebuilt T5 a lot better, financially and gearing wise.
Old 22-01-2011, 06:25 PM
crumpet
crumpet's Avatar
PMSL songyongmooso's have t5's as if, What is a straigfht swap for thge cossie t5 and would be a benefit tab?
Old 22-01-2011, 10:01 PM
LHD220Turbo
LHD220Turbo's Avatar
what power are you aiming for? the t5 is a strong old box; most are run way above what they are supposed to be rated too!
Old 22-01-2011, 10:55 PM
crumpet
crumpet's Avatar
Well 2.2 bar on a t34, Im just wondering if theres any other alternative box with differ ratios? Is their any 6 speed t5's?
Old 22-01-2011, 11:00 PM
LHD220Turbo
dont over complicate something that doesnt need to be over compliated is my advise.
why do you want different ratios? what are you wanting it to drive like?
Old 23-01-2011, 09:07 AM
Turbosimpsons
Turbosimpsons's Avatar
tko 600.they also do a 6 speed iirc. change your diff ratio if you want better acceleration.
Old 23-01-2011, 09:16 AM
LHD220Turbo
bit overkill for a t34 though dont you think? and bloody expensive
madrod runs a tko600, but then he does have over 800hp
Old 23-01-2011, 09:39 AM
Rsmat
300+
Rsmat's Avatar
Id just stick with the T5....They take plenty of abuse that a T34 can throw at them.
Old 23-01-2011, 09:40 AM
crumpet
crumpet's Avatar
exactlly, I was wondering if there was a 6 speed varient which would be cool as fook to be honest, and different to every other road going useable saph, plus might not cost much as cossie t5's are getting expensive now days!
Matt i spose, does anyone know the ratios of a t5?
Example at 7200 rpm what speed would you be doing in 1st to 5th?
cheers
Old 23-01-2011, 09:54 AM
Turbosimpsons
i suppose it is. iirc they are about £1700 just for the box. how many people stay at the horsepower they have. not many! fit and forget.
Chas
21-09-2015 08:57 PM
gingerturbo
18-08-2015 07:58 PM
COSWORLD
14-08-2015 07:40 AM
wheelwizardrefurbs
04-08-2015 06:23 PM
Quick Reply: tremec xr3r gearbox fit yb? difference from T5?
